12 volt 8 Segment LED hookup to Microprocessor?
I have an 8 segment LED that requires 12 volts that I want to drive either from a microprocessor running at 3 or 5 volts.
I'm looking for advice on how to minimize the component count for doing this since the only way I can think of is having a Transistor for each output from the Microrocessor.
Paul Baker
The other option is to use a LED segment driver chip which can drive a common cathode, however none are made (that I could find) that work at 12V.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 4/30/2007 5:54:08 AM GMT
12V 12V ^ ^ | | \ | / | \ / +---|< pnp | \ | | / LED --|< npn | \ --- | - --- -Actually come to think of it you can just use an optoisolator, since theres no galvanometric connection you can perform the control. Connect the cathode of the LED in the optoisolator to ground and connect the anode to your I/O pin (through a resistor first) you then can use the phototransistor to directly control the segment.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 4/30/2007 9:17:11 PM GMT
