Printing on Project boxes
Professorwiz
Hello All,
I had an idea for a gadgit I wanted to sell on the Inet, I've got the electronic part of it down, but does anybody know how to get the fancy printing on the boxes?· You know the "ON" and "OFF" above the buttons or on the buttons for that matter?· I think it's a silkscreen process or could be done with stickers.· I was wanting more the silkscreen type paint process but have searched abit and couldn't find anything.
Russ
Russ
- Rick
Do you know where I would go to have this done?
Russ
Most moderate cities will have a screen printing business that can steer you in the right direction.
- Stephen
www.eastcoastmarc.org/front_panels.htm
showcase.netins.net/web/rmw/panels.html
www.kkn.net/archives/html/QRP-L/2002-02/msg00324.html
You can get laminators that will do up to 8 1/2 x 11 or so sheets of paper at places like Wal-Mart or Office Depot, etc. for around $30.
I plan on getting one and trying it on my next project...I'm tired of those rub-ons.
- Rick
Turns out now there is a way to make cheap 4 color process subsurface printed 10 and 15 mil LEXAN labels with adhesive back as well as clear tinted front areas for graphic display. I have a digital printer I can make print 1000 12 x 18 inch sheets per hour with no setup. That means I can make just ONE sheet as simple as you can output on a laser printer.
Send me your requirements. $50.00 minimum order. That will get you five 12 x 18 inch sheets. If your panel is 8.5 x 11 then you would have 10 panels. As many as you can fit on the sheet.
Check out my company site at www.ccspecial.com
Email me at mark@ccspecial.com with your requirements.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Kenny Gardner
GAP Development Company
http://www.gapdev.com/
