Power Supply Question
Hello Everybody,
This is my first post, and I am pretty new to most of this. I bought a PDB and a BS2px24, and have a question about power supply.
The recommended supply for the PDB is 12V@1A, the BS2px24 gets powered via the board and all is well!
My question is: I have lots of power supplies doing nothing, between 9V and 12V. However, none of them operate at 1A. What is the limit in current supply to the LM1084 for the board/BS2 combo.
I hope to be able to learn as I go and my son and I eventually want to build a robot, but it's baby steps for us at the moment.
Thanks for any suggestions.
Damian
Damian
- Rick
You should be aware that most of these adapters are not regulated and their voltage spec is for when they are fully loaded, so when little or no current is being used, the voltage tends to rise. A 9 volt un-regulated adapter will be closer to 14 volts with no load.
- Rick
