Simple X-tal question — Parallax Forums
Nick MuellerNick Mueller Posts: 815
edited 2007-04-25 15:27 in Propeller 1
Hi!
Sorry if that sounds dumb. I simply don't understand the data-sheet.
My question is: Can I use a 20MHz x-tal?
Or more general: What's the frequency-range of x-tals that work on the propeller?
Of course, the maximum PLL factor will be 4 with the 20MHz x-tal.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
    edited 2007-04-25 09:54
    I think NO.
    You can use 8Mhz, maybe 10Mhz at tops.
    As I recall, the PLL is always 16X and then divided down.
    So 20Mhz would overclock at 320Mhz!
    "If you want more fiber, eat the package.· Not enough?· Eat the manual."········
    ···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
  • KaioKaio Posts: 287
    edited 2007-04-25 12:22
    Nick,
    you can use a crystal up to 80MHz, but then you can not use the PLL. If you want to use the PLL then you must use a crystal in the range of 4 - 8MHz. Please refer also the Propeller manual at page 29 to set the right configuration depending from your crystal frequence your are using.
  • Nick MuellerNick Mueller Posts: 815
    Thanks Kaio!
    Now I understand the data sheet.
    The question arose, not because I can't invest in an 5MHz crystal, but to reduce inventory with a bag of 20MHz x-tals sitting around for an other project.
    Nick
    YADRO
