Atari Joystick Object
Oldbitcollector (Jeff)
This contains my first stab at creating an object for Propeller...
This is an Atari Joystick Object for the joystick on the VGA header experiment.
Zip contains joystick driver, build schematic, as well as a nes driver for drop-in conversion
of existing hydra games and demos which use the NES controls.
Let me know what you think.
Oldbitcollector
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
Post Edited (Oldbitcollector) : 4/20/2007 4:28:00 AM GMT
Oldbitcollector
That's just what my tank requires.
Rich
I'm curious as to why you've got pin8 of the joypad going to pin9 of the vga, isn't vga pin 9 unconnected?
I thought most VGA's just use 123 = rgb, 678 = rgb ground 5,10 = ground, 13,14 h,v sync ( HV and RGB order could be wrong way round, as it's off the top of my head as i type this )
Baggers.
Oldbit
