controlling relay w/a stamp?
hi,
i'm trying to make a project where different sound sources are inputted and either one source or the other will be outputted. i'm trying to do this with a bs2 & a relay and am having a lot of trouble because the lowest voltage relay i could find was a 5V, however, even with a transistor to ramp up the voltage coming from the stamp and into the relay, the best I can get it up to is 4.5 V, therefore the relay won't work because it's not getting enough power. Any suggestions?? I was trying to do this previously with a digital potentiometer instead of a relay but had even more problems with getting that one to work..
thank you,
kiera
thank you,
kiera
Here is a link to one that has 16 analog inputs independently controlled/isolated from the other;
focus.ti.com/lit/ds/symlink/mpc506.pdf
Bob
There are other options to switching audio like Jfet transistors and audio switching IC's. For simplicity, you should be driving an NPN transistor by the Stamp, the relay has as fixed positive voltage on one pin, the other pin gets sent to GND by the NPN transistor which is driven by the Stamp pin. Google NPN relay driver, there will be tons of stuff to look at.
Post Edited (TChapman) : 4/7/2007 10:35:38 PM GMT
There are no Undo buttons in life.
http://forums.parallax.com/showthread.php?p=632696
Quattro
'Necessity is the mother of invention'
http://www.winford.com/products/cat_rly.php
But, I am a little confused since I have switched relays directly from a HIGH on a BS2. coto makes 5V coil relays with built in diodes....
