Driving BS170 FET From BS2 pin
Hello,
I need to switch 1 Amp (max)·at 12 Vdc and plan to use a BS170 FET.
Can I connect the BS170 directly to a BS2 pin? Is a resistor needed between the 12Vdc supply and the BS170?
Should an optical isolator chip be used to protect the BS2 if something happens to the BS170?
I assume a logic HIGH on the BS2 pin will turn the BS170 FET on. Is this correct? I've not worked with FETs before.
Thanks.
Thanks.
If I replace the relay, in the circuit diagram you provide, with a 12 Vdc fan do I need the diode?
BTW, the BS170 is a poor choice to drive with a BASIC Stamp. Its gate threshold voltage is too high, and its transfer characteristics are spec'd with a VGS of 10V. Use a "logic MOSFET", like the IRL520 shown in PJ's schematic. It will turn on fully with a 5V drive signal. (And yes, even with a fan, as with any inductive load, you need that diode, unless the MOSFET is protected internally with a zener between drain and source. But even then, I'd include the diode.)
Post Edited (Phil Pilgrim (PhiPi)) : 4/21/2007 1:55:39 AM GMT
What do you think? Do you understand why a diode would be used or needed? It's been mentioned before and is in the various Parallax tutorials.
What difference would it make if you used a diode in this way and it wasn't needed? You need to know these things.
Also, thanks to everyone else for your help. I'm ok now.
