Program DS1620 as a stand-alone thermostat using BS2
I have a new project where I need to program a DS1620 as a stand-alone thermostat.
The Parallax DS1620 App Note had example code for a BS1, but not a BS2 (unless I missed it).
Other code I've found was in VB6, or was too involved.
Does anyone know where some simple BS2 code, which can be pasted into the BS2's IDE, may be found? All I need to do is program the DS1620's upper and lower set points.
Thanks.
Thanks.
Tracy Allen
www.emesystems.com
I need help with one last thing. The following piece of code-
' set the upper threshold= +7.5 deg C· shiftout 15,14,lsbfirst,[noparse][[/noparse]1,15\9]· ' upper threshold=15/2=7.5 deg CI don't see how one gets the 15/2=7.5 How would I change the code for +26 deg C (80F) and +29 deg C (85F)
http://forums.parallax.com/showthread.php?p=601101
Chris Savage
Parallax Tech Support
specifies a threshold of 7.5.
So for thresholds of 26.0 and 29.0 you would use 52 and 58 respectively. Don't forget the \9 for nine bits.
Tracy Allen
www.emesystems.com
See;
http://www.parallax.com/dl/docs/books/edu/WebAppliedSensors-v1.4.pdf
It lays out a nice easy to understand thermostat with the DS1620. I am having trouble however with displaying the 0.5 decimal part of the DS1620... see my post to follow.
