HB25 question
I have been wanting to buy a new "base" for some time. I have bought a bunch of componets to that end. I am looking at or thinking about this http://www.lynxmotion.com/Category.aspx?CategoryID=57. the thing is it has 4 motots.
so im thinking i can hook them up in parallel and drive each side with one HB25. is that possible?· even in parallel they wont draw enough current to even come close to hurting the drivers.
also any other bases out there that you guys like?
IC layout designer
Austin Texas
IC layout designer
Austin Texas
http://www.lynxmotion.com/images/html/proj071.htm
cabojoe might have some good insights.
Whit+
The HB-25 can accept multiple motors on one HB-25 that will be driven at the same relative speed/direction. That is, connected with the same polarity a second motor (of the same type) will move in the same direction and speed. Likewise connecting it with the polarity reversed will cause the speed to match by the direction to be opposite. If the maximum stall current of both motors is under 25A you should be fine. Take care.
Chris Savage
Parallax Tech Support
IC layout designer
Austin Texas
I have been looking for a while and short of building my own this is the closest thing i can find.. (link in first post)
IC layout designer
Austin Texas
Tom
Robot vision is the the future, and Vision will take us there.
It's not quite as big as you wanted though.
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning.
Microsoft: "You've got questions. We've got dancing paper clips."
im still looking for something better than the lynxmotion rover, if anyone has any ideas.
IC layout designer
Austin Texas
Lots of people toss or sell for a few bucks their old RC cars (look for them in garage sales, recycle stores). Those chassis can be cannibalized for parts (wheels, suspensions, drive trains, motors and gearbox, electronics (RC, H-bridge), etc. Adapting them to be under partial control of a Stamp, adding sensors, etc, ·provides a cheap "base" as well as an interesting project in system integration.
PAR
what i really want.
1) a bot that can navigate indoors and out. in is more important but I do want something that can do light outdoors traversing.
2) bot must be able to go at walking speed
3) have a 12 pound payload
5) big enough to carry a small x86 computer(way future) micro atx board? or is it a mini atx? I cant remember which is···· smaller at the moment.. the one i have in mind is about 9" x 8"
6) 12v motors.
I spoke with lynxmotion and the guy there told me that the 4x4 rover is limited by the tires as far as weight. the tires he said are hollow and after about 6 to 8 pounds start to depress. other than that this rover is just about what im looking for. its about 2 to 3 inches smaller in long ways that I want. the only other thing I would like to have is something that is quite. geared motors make alot of noise, I was really hoping to find something that is rather quite. dont know if that exists..
this should be a good platform that will last through many many changes that im sure i will test or make.
the only reason I ask the question is that some of you may know of some website I have not seen before? with a base that is better or costs less. 178.00 or so is not bad really.
IC layout designer
Austin Texas
Post Edited (Rontopia) : 4/19/2007 7:22:43 PM GMT
Another vendor with many bases is Trossen Robotics
http://www.trossenrobotics.com/store/c/2658-Differential-Steering.aspx
Regarding the hollow tires. It may be possible to fill them with something, expanding foam or some type of plastic. In the MIT 6.270 course they fill lego tires with rubber bands to keep them from collapsing.
PS.· If we win the lottery, the MMP-30 would be nice.·
one of them looks like a RC truck with the body pulled off and a flat piece of PVC attached.. 500 big ones. wow and those 5000 dollor bases.. even if the wife would let me spend that much on my hobby, 5000 bucks!! wow.
anyway thanks for the links. I will read up on these.
IC layout designer
Austin Texas
Post Edited (Rontopia) : 4/19/2007 8:56:09 PM GMT
Go for a mini-ITX or nano-ITX. Mini-ITX ($150-$200 with processor) boards are 170mm X 170mm. Nano-ITX motherboards ($300+ with processor) are 120mm X 120mm. The nano's are about as small as your going to get for a motherboard, they are made by VIA corporation.
IC layout designer
Austin Texas
