Parallax (and others) sell strips of these. I often buy 28 pin IC sockets where the two sides are just held together by thin strips of plastic and cut those strips out which leaves nice 14 pin socket strips.
Are you looking for a header or a SIP socket? Typically these are available in longer units and we cut them down to size. Once you confirm what you need I may be able to help you out. Take care.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
Chris Savage
Male - http://www.mouser.com/catalog/629/1111.pdf
Both (std and Swiss machine pin) - http://www.sparkfun.com/commerce/categories.php?cPath=53_91
Good luck, Steve
BTW - Mike's suggestion of using "open" DIP sockets works great also in a pinch.
thanks!
