How do I use the extra memory in the BS2sx? — Parallax Forums
HkySk8r187HkySk8r187 Posts: 14
edited 2007-04-17 03:45 in BASIC Stamp
I was using the BS2, which has 2k EEPROM program size ~500 lines. My program hit the limit and would no longer fit in memory. I got the error "Data occupies same location as program". I'm guessing that it's because I have about 650 lines of code so far.
So I remove hte BS2 and put on my BS2sx which says it has 8x2k EEPROM program size ~4000 lines. I get the same error, and the memory map looks identical as it did with the BS2. I thought this chip was supposed to hold 8 times the amount of code?
I don't get it. Can anyone help? Thanks.
  • allanlane5allanlane5 Posts: 3,815
    edited 2007-04-14 19:37
    You need to use "multi-bank" programming.
  • HkySk8r187HkySk8r187 Posts: 14
    edited 2007-04-14 19:43
    Ok guys I decided to just post my entire program. It's basically controlling some LEDs to give a light show with the beat of a song. There is going to be a lot more yet to come and I've already ran out of space. Any help would be appriciated!
    ' {$STAMP BS2sx}
    ' {$PBASIC 2.5}
    LEDs          VAR   OUTL ' LEDs on P0 - P7
    LEDsDirs      VAR   DIRL ' DIRs control for LEDs
    SongSpeed             CON   428  ' Calibration value
    DeBounceTime          CON   20
    WholeBeatTime         CON   SongSpeed / 2
    WholeBeatTimeNoNote   CON   WholeBeatTime + DeBounceTime
    BtnBlank          DATA     %00011111
    BtnG              DATA     %10001111
    BtnR              DATA     %10010111
    BtnY              DATA     %10011011
    BtnB              DATA     %10011101
    BtnO              DATA     %10011110
    ' -----[noparse][[/noparse] Testing / Setup Defines ]-----------------------------------------
    #DEFINE Calibrate = 0
    Reset:
      LEDs = %00011111     ' Start with all buttons depressed
     LEDsDirs = %11111111    ' Make LEDs outputs
    Main:
      #IF Calibrate #THEN
          DO
          READ( BtnBlank ), LEDs
              PAUSE DeBounceTime
              READ( BtnG ), LEDs
              PAUSE WholeBeatTime
              PAUSE DeBounceTime
              READ( BtnR ), LEDs
              PAUSE WholeBeatTime
          LOOP
      #ENDIF
     GOSUB Sequence1
      END
    Sequence1:
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnY ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnY ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnY ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE DeBounceTime
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnY ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnG ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnO ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnB ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnR ), LEDs
     PAUSE WholeBeatTime
     PAUSE 20
     READ( BtnY ), LEDs
     PAUSE WholeBeatTime
      DEBUG "END OF PROGRAM!", CR
      DO
          PAUSE 10000
      LOOP
    edited 2007-04-14 20:26
    The way you're doing the sequencing is very wasteful of space. It looks like you're always setting certain LEDs, holding that setting for a specific time, then blanking the LEDS for 20ms ... always. You should have a DATA table in EEPROM, one byte for each beat and a pointer (index) into the table, then
    BtnBlank   CON    %00011111
    BtnG         CON    %10001111
    BtnR         CON    %10010111
    BtnY         CON    %10011011
    BtnB         CON    %10011101
    BtnO         CON    %10011110
    table DATA BtnG, BtnR, BtnY, BtnB, BtnG, ...
            DATA ' ... more and still more...
    endtbl  DATA 0   ' To mark the end
    sequence:
    i = table
    do
       read i,temp
       i = i + 1
       LEDs = temp
       PAUSE WholeBeatTime
       LEDs = BtnBlank
       PAUSE DeBounceTime
    loop until i = endtbl
    edited 2007-04-15 00:31
    Thanks. Will I have enough memory to hold say 1,200 data entries?
    edited 2007-04-15 00:33
    Also, how do I do "multi-bank" programming? Any examples anywhere?
    edited 2007-04-15 00:41
    I think you would have enough memory for 1200 table entries. Worst comes to worst, you could store two entries in one byte easily enough (as nibbles) since there are really only 6 possible choices. You could even store 3 entries in a byte (6 * 6 * 6 = 216) if you needed to with only slightly more complicated code.
    For a discussion of multi-slot programming, look at the PBasic manual in the section on the RUN statement and this Nuts and Volts column: www.parallax.com/dl/docs/cols/nv/vol3/col/nv87.pdf.
    edited 2007-04-15 01:10
    Thank you Mr Green you have been most helpful! I may be coming back to these forums seeking help again when I feel stupid again [noparse]:)[/noparse]
    edited 2007-04-15 01:31
    Having looked at your code, you probably want to do something like the linked set of code.
    This does in a single READ and a subroutine call what you did in 4 lines of code before.
    edited 2007-04-17 03:15
    How could I store two entries in a byte? Using the table I have enough room to store 1200 entries, however each entry needs to have a cooresponding delay time from the previous entry.
    I am not always waiting 'WholeBeatTime' after an entry, sometimes I want to wait (WholeBeatTime / 2), or (WholeBeatTime * 2)
    This creates 2400 table entries for 1200 instructions, so getting even more out of the memory would be necessary.
    You could do that by thinking of each byte in the table as a combination of an led pattern and a time to hold it. There are six possible led patterns and I don't know how many durations, but less than 16. In each byte of data, use the low nibble as an index to the led pattern and the high nibble as an index to the duration. So in the following, action0=$21 would point to the BtnG pattern and hold it for wholeBeatTime.
    Here is a modified version of the program Mike posted:
    BtnG         CON    %10001111
    BtnR         CON    %10010111
    BtnY         CON    %10011011
    BtnB         CON    %10011101
    BtnO         CON    %10011110
    table DATA action0, action1, action2, action3, action4, ...
    sequence:
    i = table
    do
       read i,temp
       i = i + 1
       lookup temp.nib0, [noparse][[/noparse]btnBlank,btnG,btnR,btnY,btnB,BtnO], LEDs   ' possible patterns
       lookup temp.nib1, [noparse][[/noparse]wbt/4,wbt/2,wbt,wbt*2,wbt*4], beatTime  ' possible times
       LEDs = temp
       PAUSE beatTime
       LEDs = BtnBlank
       PAUSE DeBounceTime
    Tracy Allen
    www.emesystems.com
