Multi Slot Programming Help.
I have a problem when running in slot 1, I need to get back to a certain point in slot 0....
Example: RdTemp in Slot 0 and I do not want to start at Main in Slot 0
Does this make sense.
Tried doing this but it won't work: Run 0 RdTemp
Thank You
Guido
Thank You
Guido
There is no way to do this with the RUN statement.
In other words, you MUST start with Main in Slot 0, but the first thing that Main can do is to GOTO RdTemp if a global variable is set to a particular value which is non-zero and set by the program in Slot 1.
