Total Noob wants to learn about controllers and make a garage open device at th
Hi all,
totally new to controllers, so please bear with me.· I have an ME background and electronic packaging experiance so I am not totally blank with regard to EE stuff, but I have no clue about controllers.· As such I would like to learn, and do a project at the same time.
I would like to probably work with a basic stamp as those seem to be the most versitile, but I am open to recomendations.
I want to create a device that will warn me when I forget to close my garage door.· (I am new to using my garage for parking
)· I want a device in the car that will look for a wireless signal coming from the garage, and if I get more then 1/2 the working distance of the signal range without recieving a "closed door" signal the device would warn me about an open garage.· (Might have to use two signals, so that I do not have to get any input such as car is in Drive or Reverse from the car.)
Should be simple enough, but I have no clue how to start...
Thanks for your time.
Mark.
Mark.
I can’t offer any suggestions on the radio system due to the inherent obstacles you’d have to overcome there, however I can suggest a different approach. Perhaps what you could do is implement an occupancy sensor with a timeout. This would be similar to lighting that shuts off after not detecting people after a certain amount of time. But you could also use a PING))) sensor to detect the car being in the garage (see link below) and after no occupancy start the door closing. That could be preceded by an alarm sound in case someone was working in the garage and wanted it to stay open. They could then hit an over-ride button. Just an idea…Take care.
http://forums.parallax.com/showthread.php?p=636791
Chris Savage
Parallax Tech Support
Post Edited (Chris Savage (Parallax)) : 4/11/2007 9:39:20 PM GMT
As far as an actual kit, either the Basic Stamp Discovery Kit or the Basic Stamp Activity Kit would make a good first choice. If you're planning a long-term investment in microcontrollers, also consider starting with the StampWorks kit. It is a more advanced kit, but you could still use it to complete some of the more beginner-friendly texts, such as "What's a Microcontroller." You would just need to wire the circuits a bit differently. The benefit, however, is that you would have a lot more flexibility with the Pro Development Board over the other kits.
Chris Savage
http://www.rentron.com/remote_control/R8_4BIT.htm
This could provide a constant on signal that the controller could read.· I suppose with something so simple I could use transistors to just switch a buzzer and light, but that would be too simple.·
Should be doable now?
I would bet that after a few days of the chime you would be hitting the close button ASAP
You could do·something like this at this post this was one of the frist·projects that i made
http://forums.parallax.com/showthread.php?p=539835
In this post I·show some·details on how did this
http://forums.parallax.com/attachment.php?attachmentid=40528 Ping Sensor mount on the Garage Door
http://forums.parallax.com/attachment.php?attachmentid=40527· LCD Display
This LCD Display is mounted on the wall next to door to the·Garage· the LED light is programed to come on and STAY ON
as long as the door is open any amount the LCD Display shows how much the door is open
·One thing that i am think about·doing is if the door is open for more than 30 minutes the door will close by it self
http://forums.parallax.com/attachment.php?attachmentid=40526··Power Supply
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 4/16/2007 1:37:01 AM GMT
