SX-Key Hot? — Parallax Forums
SX-Key Hot?
quamperquamper Posts: 1
edited 2007-04-14 19:37 in General Discussion
I just got a SX programming kit a couple days ago.. I'm noticing that the SX-Key gets kinda hot to the touch while I'm using it though.
It's working fine so far and haven't had problems.
I was just wondering if I should be concerned or is that normal?
  • CCraigCCraig Posts: 163
    edited 2007-04-12 15:07
    I think it depends on how fast your running it. I use mine alot at 50MHz and it gets warm but not hot. I think it's normal to run warm at the higher speeds.
    HTH, Chris
    I had this problem too when i first got my sx-key. so I contacted parallax and they said send it back, they checked it out, and said theres nothing wrong with it, and tried to charge me for it.
    I was pretty mad because no one really told me what the normal temp of the key was supposed to be. Or made any attempt to troubleshoot it with me. I ended up paying for half the cost of the sx-key, but ended up getting a free one in the process. So in the end I got 2 sx-keys for the price of 1 & 1/2.
    Basically I found that the sx-key is pretty warm when in use, but never gets so hot that you can't put your finger on it constantly.
    It should never get too hot to touch.
    Meh. Nothing here, move along.
