NO....................problem
My adapter works on COM 8 and works fine until I use the Clock or Device functions in the SX-Key IDE, then the SX-Key is no longer recognized. If I leave the clock alone at 400 khz Debug works fine. But like I said, clock or device I get a comunications error and then the key is no longer recognized
All Functions work perfect with the serial port cable connected to the sx key?
bill
Post Edited (Capt. Quirk) : 4/13/2007 2:02:19 AM GMT
bill
Can you verify that your exact same setup (same SX-Key, same SX board being worked on, same power supply, etc) works with a regular, non USB COM port?
It seems odd that the clock and device don't work since the communications between the IDE and the SX-Key is pretty simple for those functions. The debug function is the most communication intense, and yet I assume that works since you didn't say otherwise.
PeterM
The exact same·set-up on my PDB, with the serial connection and SX-Key, works fine. Until I add the Parallax USB to Serial adapter.
I·am going to try it on my laptop and make sure it's the hardware and not the software
But I have been getting the·error messages on the clock for at least a month.
I'll post back asap
bill
Post Edited (Capt. Quirk) : 4/13/2007 1:35:02 AM GMT
Thanks PJMonty
Bill
