Microsoft Robotic Studio BLuetooth BoeBot
I downloaded the http://www.parallax.com/dl/docs/prod/robo/MSRS-Bluetooth-Boe-Bot-v1.2.pdf·and on page 11 and 12 is an exercise that tests whiskers and IR sensors on the BoeBot. My problem is that my right ir sensor will only work with my eb500 card removed from BOE. Has anyone else had this problem? Any help or advise would be greatly appreciated. Thanks
Tom
P.S. All of the excercises up to this point have worked great. MSRS and bluetooth worked great ( I thought I would have some stress setting it up, but it was easy with the well written instructions).
Tom
,Travis
Post Edited (fmx95) : 2/23/2007 11:52:49 AM GMT
Tom
It sounds like the eb500 is sending a signal to one of those I/O pins.· It shouldn't be doing that because its hardware flow control feature should be disabled by default.· For a little background, see page 114 in the eb500 manual.· The comment about "high Z inputs" applies here.
On page 114, it also says that CTS "transmits flow control".· Page 131 of the eb500 module lists CTS as connected to P3.· So, if the CTS pin is transmitting, it means that instead of just listening to the circuit (having no effect) it holds the P3 connection at either 5 V or 0 V.· If you have a voltmeter, you can test to find out if that's what it's doing.· Here's how:
- Run End.bs2 first.· This ensures that the BASIC Stamp 2 has no effect on these pins.
- Move the Board of Education's 3-position power switch to 0 to turn off power.
- Disconnect the resistors from P2 and P3.·
- Plug a 10 k resistor (brown black orange) into P3.·
- Connect the voltmeter's positive lead to the end of the resistor that's plugged into P3.·
- Connect the voltmeter's (common/ground/negative) lead to Vss.
- Connect the other end of that resistor to Vdd.· (Careful not to let part of it touch anything else!)·
- Move the·3-position power switch to 1.· The voltmeter should read 5 V.
- 3-position switch to 0.
- Unplug that end of the resistor from Vdd, and plug it into Vss.·
- 3-position switch to 1.· The voltage at P3 should then be about 0 V.·
I vaguely remember that there is a typo in the eb500 that·swaps the pin assignment for CTS and which is RTS.··This in mind, I would recommend repeating the test on P2 just to make sure the eb500 is leaving both P3 and P2 alone.· I did it on my Bluetooth Boe-Bot, and the 10 k resistor did in fact pull both I/O pins high (5 V) and low (0 V).· That's to be expected since my eb500 also doesn't interfere with IR circuits connected to P2 and P3.Back on page 114 of the eb500 module, it also explains how to set the eb500's flow control pins to input, and·make it persist.· On page 11 it talks about resetting the eb500 to factory settings by shorting the status and mode pins (eb500 pins 8 and 9 which is equivalent to using a wire to connect P5 and P6) and then applying power to the device.·
After doing this, if the eb500 still isn't letting go of P2 and/or P3, there are a couple of things we can do.· One thing would be to connect the IR part that the eb500 is interfering with to P11, which is currently unused.· The .bs2 files can then be modified to use P11 instead of, say P3.· In the meantime, I'll check with A7 Engineering (the eb500 manufacturer), and find out if they have changed the default settings for their modules (and the flow control pins).
Regards, Andy
Andy Lindsay
Education Department
Post Edited (Andy Lindsay (Parallax)) : 2/23/2007 10:35:48 PM GMT
Tom
Can you provide me the serial number on your eb500-SER? I want to take a look at the manufacturing information and make sure that this unit tested out properly prior to shipment.
Sincerely,
Bryan Hall
A7 Engineering
The serial number is 0003134. Thanks for looking into it.
Tom
I have reproduced your problem and you are right that pin 6 (CTS) is not properly tristating on the eb500-SER rev.C when flow control is disabled. We have not yet determined what the problem is but we are looking into it. The rev. C hardware has a few changes around the RTS\CTS lines in preparation for the v2.1 firmware release and that is currently the prime suspect for this issue. My guess is that Andy has rev. B hardware and therefore does not see this problem.
I will keep you posted on our progress
In the short term do you have another I/O line available that you can use for the IR device instead of pin 6?
Sincerely,
Bryan Hall
A7 Engineering
eb500-Ser C S/N 0003231
Just figured I'd let someone know.
One cool thing I did do was connect my Xbox 360 controller and used it to control the Boe-boe, next thing I want to do is get the wireless reciver for the Xbox360 wireless controller, and use that to control it, would be pretty neat.
Chris
Thanks for looking into this for me. The response from A7 and Parallax on this issue has been fantastic. You guys can consider me a life long customer. Thanks Again
Tom
eb500-SER C Notice (.pdf)
These instructions are also available from the Embedded Blue Transceiver AppMod and Bluetooth Boe-Bot for Microsoft Robotics Studio pages:
EmbeddedBlue Transceiver AppMod
Boe-Bot® Kit for Microsoft® Robotics Studio
Andy Lindsay
Thanks. I saw that notice and took care of the pin
Tom
Any old USB Bluetooth adaptor "should" work. I haven't tested this particular module or seen any reports on it. The two I have personally tested are the Targus USB Bluetooth 2.0 adaptor with EDR (works on both XP and Vista) and the Dlink DBT-120 (works on XP but not Vista).
Andy Lindsay
Post Edited (Logicalsifter) : 4/12/2007 6:35:54 PM GMT
Andy Lindsay
Andy Lindsay
Andy Lindsay
Andy Lindsay
