Controlling Double A Battery Powerd Motor
I need to turn on a motor which was taken from a hand held drink mixer with a Basic STAMP II. The motor uses TWO Double A batteries and I would like to be able to turn it on and off to mix a solution in a reaction chamber for my senior design project. I have the motor mounted above the chamber with the stirrer bellow and the wiring exposed above.
My entire setup (stamp, micropumps, etc..) is being powered by a common 12V DC battery. I have a 5V regulator for the stamp.
Should I use a relay that just tells the motor to turn on (I assume that I will need to use the double A batteries to power the motor)? If so could you recommend a relay that would work?
I thought that this would be the simplest way to accomplish the task with out building a new circuit with regulators and transistors but is there better way for me to do this?
Thanks for the help everyone.
Chris Savage
Parallax Tech Support
The motor/mixer that runs off the AA batteries is secondary. This may be a off the wall question for here, but I assume that the two AA batteris that power the motor are in series, therefore the motor uses 3V to run. Is this assumption correct?
The reason I ask is because I am wondering if it would be possible to just use a single 5V to 3V regulator to power the motor (from the stamp to the motor and to into a common ground for the 12V battery)?
I would like to just use a relay that switches on the motor using the AA batteries. Do I have any other options?
I am in biomedical engineering, not electrical, so I am not well educated in all of this circuitry.
Thanks again for the help guys...this forum has been a life saver in the past.
Look at the datasheets for the regulators for suggestions for filter capacitors and wiring diagrams.
