Rechargeable battery circuit
I want to take Basic Stamp to the next level by making it potable with rechargeable battery. Here are the requirements:
-········ When wall adapter is not plug in, the circuit is running of 9V Lithium (Li/Mn2) rechargeable battery.
-········ When wall adapter is plug in, the circuit is using power from wall adapter. At the same time, it charges the battery and automatically shut of the charging circuit when the battery is fully charged.
This is similar to laptop battery system. Any idea of what IC should I use? Circuit diagram? Application note? Any material that I can read to make this happen?
