Negative (-) is it ok to do this
Can someone tell me if it is alright to share a negative (-) terminal on 2 devices.
More specifically the power source to the relay (5v) and the propeller (i am using a Proto Board now).
Only the negative (-) terminal.
5v (+)
prop (-)
Relay (-)
Thank you
5v (+)
prop (-)
Relay (-)
Thank you
Paul Baker
Is this what you are suggesting?
Thank you
