Speed trials list
TimC
HI All,
In the April Issue of Nuts and Volts there was an article by Chuck Hellebuyck about running a simple test to see how processors compared in speed. Since I have a bunch of chips myself I thought it would be fun to compare more. I ran all the chips at the top speed so in the case of the PIC's and AVR chips they are all running at 20Mhz. I agree with everything he printed in Nuts and volts so I combined it all:
The task is how fast can the processor increment a variable 255 times
For the basic stamp here is the code:
In the 'C' world the code is like this (the delay is shorter so I can measure the ON period better)
If anyone has anything they want to try please add it.
Regards
Tim
PICAXE 28x @4mhz 368msec from N&V
BasicStamp2 278msec
Basic Atom 68msec from N&V
BS2px24 60msec
Javelin 22msec
PICBasic PRO PIC16F877 0.350msec
CCS 'C' PIC16FF877 0.350msec
GCC 'C' Mega32 0.192msec
ARM LPC2148 0.065msec
'{$STAMP BS2px}
'{$PBASIC 2.5}
' connections
LED PIN 0
' variables
x var byte
y var byte
Main:
'this program will loop forever
high LED
for x=1 to 255
y=y+1
next
low LED
pause 10
goto Main
end
do {
output_high(TEST_PIN); // turn on voltage
z=254;
for(; z; --z)
y++;
output_low(TEST_PIN); // turn off
delay_ms(1); // lets delay.
} while (1);
Regards
Tim
Paul Baker
