Hall sensors ? ? ?
Model 503 is a complete pwm servoamplifier for applications using DC
brushless motors in torque ( current ) mode. It provides six-step commutation
of three-phase DC brushless motors using 60° or 120° Hall
sensors on the motor, and provides a full complement of features for
motor control.
Hello folks,
··Above is part of the description of a servo·motor amp that I'd like to control with my BS2. It calls for digital Hall sensors, not an encoder. What exactly are they reffering to and would this still be available ? Could an arrangement be made using the Hall switches that Parallax sells ? Looks like most motors come with encoders, not Halls. Is the Hall "Old School" ? Should I look for something else ?
Thanks····················
motor control.
Hello folks,
The 60 deg or 120 degree sensing is like full-step or half step with a smaller stepper.
The Hall signals may or may not be brought out for your use, but I expect they are set up in quadrature so the motor controller can do reversing. The fact they advertise "full complement of features" makes me want to believe that. You may have to call the manufacturer or do some reading on some of the r/c airplane sites as thats where a lot of the current high-power 3Ph DC motors are being used.
Cheers,
Tom Sisk
http://www.siskconsult.com
Are the 3 ph brushless motors common items ?
Thanks MUCH
If you are needing motors, here is a very good source for inexpensive brushless motors with excellent tech support and sales staff. Click the button "BLDC motors"
www.anaheimautomation.com/index.html
The motors are more complicated than a brushed DC motor. You cannot just hook up a voltage to the motor and make it spin There are 3 wires(3 phases) and they run in sequences, similar in theory to a stepper, in that each each phase is controlled externally as to when it is it's turn to be on. I just happen to be designing a BLDC driver and Propeller controller board right now, and find it to be a lot of fun, much more learning and challenge than other motors/drivers. With a BLDC, you have to output a PWM and direction in a typical setup. I am not sure on your drivers you have found, but make sure that you have determined how you are going to provide the PWM from the Stamp if in fact you drivers require a constant PWM.
In a servo or closed loop system, there needs to be an encoder mounted on the shaft, the quadrature encoder output is counted by the processor, and the processor moves the motor precisely to where it is told based on the encoder count. I no not think you can manage a closed loop system from within the Stamp, so external hardware may be needed whereas the Stamp just manages the system. You use and SX or Propeller to be the PWM engine and encoder counting engine. If can be more specific on what you are tryng to accomplish, I am sure some suggestions will come that can help clarify what some options are.
Post Edited (TChapman) : 4/7/2007 8:43:52 PM GMT
1 thing I dont see, on their driver, there the Hall connections, power, motor,fwd/rev,enable, brake and optional external speed pot but where and how would I hook-up the pulse train or PWM in to the driver.
It's probably obvious, I just dont see it anywhere in the lit.
Thanks again for the excellent advise.
If you are DIY and can do SMT boards, there is a 3phase motor driver IC that I am designing some boards around called the Allegro 3938. It accepts PWM for speed, or you can force the PWM high and set the speed with a pot or DAC, it just needs a reference voltage to set the current limiting, the current sets the speed. It will operate up to 50 volts.
www.allegromicro.com/en/Products/Part_Numbers/3938/3938.pdf
Keep in mind, it may not be possible to send the PWM and DIR from a Stamp due to speed limitations, let us know exactly what you are wanting to do with more details.
Post Edited (TChapman) : 4/7/2007 8:44:46 PM GMT
All that I am familiar with and comparing this to is a stepper driver with the step and dir inputs that I am running now with the pulsout on BS2. I want to eventually progress to precisely controlled, simultaneous, 2 axis, servomotor moves, point to point. I understand that the BS2 cannot do this but the Propeller will.
I will try to keep up with your project, which forum is best to follow it in ?
I guess I was assuming that what I was looking at was a servo controller.
Thanks for clearing all of this up,
RC
For what I need, speed is not really an issue.
Any idea of the 3938 $ ?
These look similar and there are several offered that may be of interest.
Thanks again
http://cgi.ebay.com/MC33035-Brushless-DC-Motor-Controller-Qty-5_W0QQitemZ320099093695QQihZ011QQcategoryZ36332QQrdZ1QQcmdZViewItem
