New versions of the documentation (Basic Stamp Progr. Manual 2.2) apply to whic
I don't know how to find out what the difference is between my BS2
and the one mentioned in the Basic Stamp Progr. Manual 2.2.
One thing is sure, I tried some of the new commands and those
don't work!
The 2.2 manual says that it applies for BS2 firmware 1.0 and
windows interface 2.2.
When I run Basic Stamp Editor .. Identify, I get version 1.0.
I assume this is the firmware version.
Where to find the Windows Interface version ?
Ed
don't work!
Ed
Even with the latest editor, you have to specify which form of the syntax you're using (with a compiler directive in your source program). The default is the older (2.0) version. It's very clearly documented.
I'm using 2.2.6 but missed the PBASIC directive. Often it doesn't matter but in this case (some DEBUG option) it does.
Thank you for pointing me in the right direction .. directive :<)))
Ed
Chris Savage
Parallax Tech Support
