the chip has 3 'timers' right?
[url=mailto:2@8bit]2@8bit[/url]·and [url=mailto:1@16bit]1@16bit[/url]
? are the bits latched ?
I would like to take 3 pins and connect them to
the 3 timers .....
(and use these for 3 'voices')
But!
have the program procede
leaving the 3 pins giving off (worst case)
squarewaves
@ the frequencies·determend·by the
[url=mailto:1@8bit(voice]1@8bit(voice[/url])
[url=mailto:1@16bit(voice]1@16bit(voice[/url])
then be able to use the
the other pins to fire external envelope generators
(Vactrols)·
the 3 timers .....
But!
squarewaves
(Vactrols)·
One would have to use assembly?
Could one do what I want ?
You could use a plain SX processor and program it in assembly or SX/B or you could use a Propeller. Have a look at Propeller/Hydra Forum threads about the "Hydra Sound System" or HSS (like: http://forums.parallax.com/showthread.php?p=604722).
Be able to set 4 free running frequencies
and then proceed to envelope pulses:
http://www.parallax.com/detail.asp?product_id=28020
Post Edited (TChapman) : 4/8/2007 3:15:33 AM GMT
If you can set the frequency (with attendant pop)
BEFORE the envelope initiates
Then it should run much quieter.
