Do I need to insert a resistor to protect the Stamp, and if so what size?
Well you all know I am not to bright....But I do try to learn! I am going to use three stamps and one LCD Display. One stamp will control the other Two as far as which one will take over the lucky duties of the Display! How would you advise protecting the Stamps and the Serial LCD?
Guido
Post Edited By Moderator (Chris Savage (Parallax)) : 4/6/2007 5:38:19 AM GMT
Guido
It's Only A Stupid Question If You Have Not Googled It First!!
Protection is important in a project like you described. First, I would use saline (salt water) soaked sponges under each of the Stamp boards to isolate them from the nasty old ground, bypass the on-board voltage regulators (5 volts sounds a little wimpy for your project), get rid of those old DC wall wart power supplies and get yourself some good strong 12 volt AC units and "go for it"! Oh, and don't forget to wrap all of those little exposed metal parts (where all the wires go in) on the LDC with aluminum foil.
Lastly, dial 9-1 on your phone and hit the power buttons on the boards.
Good luck, Steve
Just a little Humor guy's
But if you want to, 220 ohms in series will protect a stamp pin in the situation where you're command it to output a +5 and it's really connected to ground. 220 ohms will also protect a stamp pin when you're commanding it to zero and it's really connected to a +5 output.
The Homework Board comes with these resistors pre-installed.
And this is a family comment board. Comments about Trojan Rubbers are so obscure that it's not likely to be seen as funny.· Not to mention that using them for waterproofing is sometimes appropriate.· So you're either not funny, or confusing, neither of which is what you want.· Just a thought.
