Switch closing
Good Day,
I have a newbie electronics question,· I'm working with the BS2 on a BOE.· For my project I'm going to click a shutter on my camera.· I planned on doing this by using the port on the camera that goes to a remote triggering device.· The device normally has 2 buttons, one for focus and one for "take the picture".· I figure I could just hook a relay cicuit to one of the pins and have the pin close a relay to make the closed circuit on the switch.· Am I thinking correctly?· Is there something I should watch for like voltage somehow going back though the relay and into the camera?· Similar to the reason we have to put a diode so that when releasing the relay we don't get a flyback voltage?
Thanks for any help.·
Russ
Russ
If this interface is a simple switch closure thats fine - I think you have to be sure that this remote - is as you say it is - 'a simple switch closure' - if this can be confirmed then I am sure
will not apply and you will get all the answers you need.
Quattro
'Necessity is the mother of invention'
Thanks for the help!
Russ
So what are you looking for exactly - a simple circuit to switch a relay ?
I posted this on a different thread -
http://forums.parallax.com/attachment.php?attachmentid=45487
Optionally you could use a transistor to drive the relay (or a transistor on its own - if you knew
the associated voltages and orientation of the camera interface)· but since you requested a relay circuit ·the above example shows a pvdz172n·- which is an optically coupled photovoltaic with integrated reverse biased diode on output stage ..
·········· Quattro
Post Edited (QuattroRS4) : 4/4/2007 11:55:10 AM GMT
The damaging thing was my main concern of course. I appriciate the help.
Russ
Will that do the trick for you - If you are not confident with your electronics - get someone who knows about it to give your circuit a 'once over' before you connect anything...
Quattro
Thanks for your help, the optical isolation was the direction I was thinking.· I have a couple HSR312's laying around I got on a sample order.·
I've attached the data sheet here, the internal schematic looks similar if you get a minute and can look at page 6, of the pdf, which is the schematic of the chip it looks like I could adapt this chip to your schematic using the parallel connection.· Does this seem logical to you.· If you don't have time to look, no worries, I know I'm pushing it asking all these questions.· I'm trying to learn as I go, and I will have someone that's more familiar with this look it all over before I make the connection to the camera.
Thank again.
Yeah - that looks fine as long as the current requirements to switch your relay do not exceed Imax - 320mA (if used in Parallel mode) and 190mA (in series mode). The example device in the circuit I posted has a current capability of 1.5 amps @ 60VDC.
Incidently what type (spec) of relay are you planning to use ?
Quattro
Post Edited (QuattroRS4) : 4/4/2007 2:12:52 PM GMT
To be completely honest, I haven't looked that far yet.· They were using microswitches in the remote switch I got part of the idea from.· I was thinking small reed relay, but am unsure.· Do you have an idea?
Russ
http://relays.tycoelectronics.com/datasheets/w11.pdf
you will have to choose·a vlotage which·matches the supply you will be using..
So I would need part #2-1393779-7 which has a nominal voltage of 5fdc.· I'm a little confused by the coil power, I would multiply the volts * watts to get the amps to check to see if I'm within range correct?· So 5 volts X .2 watts ?· I'm unsure of the conversion or is 200mW - .2 Watts.. sigh.. I apologize once again for my ignorance..
Rus
What is the supply going to the board - before the reg ? Battery or PSU if psu what are the specs.
Quattro
Russ
