NCO/PWM jitter — Parallax Forums
NCO/PWM jitter
sjevsjev Posts: 10
edited 2007-04-04 07:32 in Propeller 1
Hello,
I am using the following code to generate a frequency (copied from the counter application notes):
PUB StartDOD
  ctra := %00100_000 << 23 + 1 << 9 + dod_pin
  frqa := $8_0000
  dira[noparse][[/noparse]dod_pin] := 1
  repeat
The problem is that I get a pretty bad jitter (+-2% of the period).
What did I do wrong? Didn't I read the manual carefully? Or shouldn't I buy the DLP-PROP module? My oscilloscope is not fast enough to measure the clock frequency.
Funny thing is that a pulse generator at a different cog (using waitcnt) produces a pulse with a jitter sychronous to the NCO. So, does my system clock jitter???
  • CJCJ Posts: 470
    edited 2007-04-03 21:38
    I'm pretty sure the DLP-Prop is using the oscillator from the ftdi chip and that isn't super accurate, someone else had trouble using it with serial comms
    Parallax Forums - If you're ready to learn, we're ready to help.
  • sjevsjev Posts: 10
    edited 2007-04-03 22:50
    So I have measured the 6MHz clock at the XI pin.
    It jitters!!!! Damn FTDI!
    Tomorrow I'll test another chip at work ( yes, it's more than a hobby wink.gif.
    Maybe a word of warning should be added to the DLP-PROP page. Unstable frequency in industrial control applications is a pretty serious issue.
    Post Edited (sjev) : 4/3/2007 10:56:34 PM GMT
  • QuattroRS4QuattroRS4 Posts: 916
    edited 2007-04-03 23:15
    What industrial application are you using a DLP-Prop on ? Especially when its frequency generation ...
    'Necessity is the mother of invention'
    edited 2007-04-04 06:25
    QuattroRS4 said...
    I am building an inkjet printer prototype. It is just a simple research device, but the timings should be absolutely solid for a dozen of reasons.
    Yes, the other chip is much better. With a good scope Ican measure the standard deviaton of the jitter. On this one it's 0.1 %. Not rock solid, but workable. I guess my next order will be a bunch of prop sticks instead of dlp-props
