Autonomous UAV
Hi·im Justin Hulbert this is my first post on this forum.····
I was just thinking about projects that i could try to do this summer and one of them was to build an Autonomous UAV. This would definetld be pretty hard but well worth the time and money. I would first have to construct a larg working RC airplane probaly from scrach. Then id try to work off of this adding a·BASIC Stamp·and a buch of senrors GPS,3-Axis acelometer, motor control, cameras·and many more. I was just wondering if anyone had ever done this or is there a site with some information that i could read. Im just trying to figure out how ill have it fly from point A. to point B. without any human control othere than the input of cordenents. Just an idea im seriasly thinking about doing.
There are no Undo buttons in life.
This is a good point about the Basic stamp being relitivly slow around 4-20 Mhz·, since when in flight every fraction of a secout counts. I havent done much reading on them Propeller chips yet but i will do so. From what iv read on the site so far they look to be pretty cheap, are almost 9x faster than any basic stamp, and have lots of memory and plenty enuff I/O ports. This is probaly what id have to use at least for the main flight controles like calculating all the posioning and stuff.
Maybe this won't be as eassy as building a simple wheeled robot, but i have alwas been fasinated by flight. And to have a self flying "robot" that would just be alsome.· It will probal also cost quit a bit so ill have to spread the project over a pioriod of time, since im curently trying to save for a truck.
In an airplane there are two diffrent things that need to be acomplished,
1. The course or flight path. This can be done with a GPS unit. The purpose of this is to make small changes over a period of time to stay on course.
2. Stabilization. This is to keep the airplane level and right side up. Quick changes need to be made in this situation.
To control an object in flight you need to know whats called "Six Degrees of Freedom" which is acceleration and rotation for all three axis.
One of my projects using the stamp is a rocket payload that records time, acceleration and airpressure to an external eeprom. And with this I am out of variable space.
I don't know much about the propeller chip (Mayby some could tell me more about making the jump from the stamp to the propeller?). As for some thing to start with I found the BS2 to be a great learning tool and EXCELLENT support. I have been able to test several diffrent sensors and such, but to beable to read and controll everything I want just hasn't worked out (lack of variable space).
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 4/4/2007 12:39:44 AM GMT
Quattro
well if its your dream then consider it ...
"A dream which is not interpreted is like a letter which is not read." - The Talmud
Quattro
