Smooth pan-tilt system question
Hello! New member here and this entire subject is new to me. I,ve been trying to work out how to come up with a very smooth and slow pan-tilt head for a camcorder crane. I settled on DC gear motors that would be further reduced in RPM ratio to about .5 RPM.·I want to control the 2 motors speed and direction with a dual axis joystick.· After doing some research on this website and others I realized I would need an H bridge and microcontroller.· If I used the HB-25 motor controller would I need one for each motor? And would one Basic Stamp module handle the work? I know very little about this subject but what I've picked up is that code would have to be written to convert the analogue joystick output into digital pulses the HB- 25 could read. Is that correct?·· Thanks for any advice you might have.··· Dave M.
The HB-25 is, by all accounts, an excellent driver, but big and expensive (relatively) if you your motor doesn’t require so much power.
May I offer a different approach? For small motors single chips are available that will do the job; one, the SN754410 for example is less than $2, requires no peripheral components, and will control two small (500mA) motors or one larger (~1 amp); chips may be piggybacked for even greater output. If this seems adequate then purchase the PWMPAL for $30 (will output 4 PWM channels), wire one (or two) additional chips, and pocket the difference.
Another possibility is the Motor-Mind B, but I haven’t used it—perhaps others will recommend it.
Also, look at the ADC0834, it's an easy to use 8 bit, 4 channel A/D converter
The HB-25 modules are an excellent product and work really well. Note, however, that any required postion feedback will have to come from some other sensor on the crane.
I just finished a little test setup with a joystick, BS2, and one HB-25. If you're interested in the code, just let me know.
Cheers,
Tom Sisk
http://www.siskconsult.com
Dave M.
May or may not apply, Chris
Thanks,· Dave M.
It looks like you're pretty well committed to using DC gear motors for you project, but you might want to take a look at the slick pan/tilt mount that "T0m" has turned out for a bot mounted camera.
http://forums.parallax.com/forums/default.aspx?f=10&m=181523
He's quite the fabricator and if your camera is being suspended rather than the mount supporting the weight of the camera, some beefier servos on a mount like T0m's might do the trick (he says he's working on an upgraded model with ball bearings!). Also, using the Parallax Servo Controller with a setup like that would give you very precise control of position, position feedback and the ability to ramp down the movements of the servos for very smooth quiet operation and you wouldn't have to worry about component cooling like you do with the HB-25.
Just a thought, Steve
Post Edited (Duffer) : 4/4/2007 4:46:40 AM GMT
Dave M.
I wanted to add that I've seen several DIY cranes where they attempt to get a smooth pan by using fluid heads and cables or rods set up in some fashion but I've never seen this attempted except by professional set-ups with computer controlled crane heads in studios.
Post Edited (Dave M) : 4/4/2007 5:18:29 AM GMT
I had many of the same feelings regarding the use of servos for camera work until I started using the Servo Controller. My favorite things about its use are that it provides 64 "ramp" speeds for servo movement. I.E. a ramp value in the 60s causes the servo to take up to 8 seconds to make a full 180 degree rotation very smoothly. It can control up to 16 servos (32 by daisy-chaining a second Servo Controller) and its all controlled by a simple 3-wire serial connection to the micro controller using only 3 or 4 simple commands. For setting up and shooting on a repeatable path, it's a simple matter of storing the coordinated movements of your shot and just "playing them back" to repeat a shot as many times as needed. Also, with the USB version (same price as the serial model), Parallax provides a free, downloadable PC application that you can use to test and calibrate your setup before you commit to the coding.
Sorry, I don't mean to sound like I get a kick-back on every unit that's sold, but that simple little $39 board has saved me a lot of time and headaches on several projects.
Cheers, Steve
Got a little distracted with a couple other projects. Will get the joystick code up later today!
Tom Sisk
As far as servos are concerned my only experience with them is in R/C flight. I understand your point about using a controller and an 8 second 180 deg. arc.· My concern is servos, from my experience, kind of jerk to the next step. In videography smooth is good, jerky is bad. It seems that continuous running motors would move the camera more smoothly. Also I'm thinking more like 24 to 30 seconds for a 180 degree arc.
Dave M
Dave M.
I posted some code and pics over on the Sandbox.
Tom
Tom Sisk
