Two RFID Card Reader ONE at a TIME ........Cards 10 and 11 Shows.."Unauthorized
Hi EveryOne
I want to know if i have this right·
·using Two RFID· Card·readers with one Basic Stamp.............. Read one card reader at a TIME.......................
Is there AnyThing· that·I need to add to this Routine to make this work
Enable1········· PIN···· 0······················ ' low = reader..1 on
RX1············ ··PIN···· 1······················ ' serial from reader..1
Enable2········· PIN·····2······················ ' low = reader..2 on
RX2·············· PIN·····3······················ ' serial from reader..2
Reader1:
· LOW Enable1··································· ' activate the reader
· #IF __No_SPRAM #THEN
··· SERIN RX1, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10]··· ' wait for hdr + ID
· #ELSE
··· SERIN RX1, T2400, [noparse][[/noparse]WAIT($0A), SPSTR 10]
· #ENDIF
· HIGH Enable1·································· ' deactivate reader..1
Display_Tag:
· DEBUG "Tag Identification number is: ", CR
··· FOR idx = 0 TO 9··························· ' scan bytes in tag
····· #IF __No_SPRAM #THEN
······· DEBUG buf(idx)
····· #ELSE
······· GET idx, Char······················· ' read char from SPRAM
······· DEBUG Char
····· #ENDIF
····NEXT
· DEBUG CR
· PAUSE 500
· GOTO·Reader2···························· ' GoTo Reader...2
Reader2:
· LOW Enable2··································· ' activate the reader..2
··· SERIN RX2, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10]··· ' wait for hdr + ID
· #ELSE
··· SERIN RX2, T2400, [noparse][[/noparse]WAIT($0A), SPSTR 10]
· #ENDIF
· HIGH Enable2·································· ' deactivate reader..2
Display_Tag:
····· #ELSE
······· DEBUG Char
····· #ENDIF
····NEXT
· DEBUG CR
· PAUSE 500
· GOTO·Reader1···························· ' GoTo Reader...1
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 5/6/2007 2:48:23 PM GMT
·using Two RFID· Card·readers with one Basic Stamp.............. Read one card reader at a TIME.......................Is there AnyThing· that·I need to add to this Routine to make this work
Reader1:
· #ELSE
· #ENDIF
Display_Tag:
····· #ELSE
······· DEBUG Char
····· #ENDIF
····NEXT
· DEBUG CR
· PAUSE 500
Reader2:
· #ELSE
· #ENDIF
Display_Tag:
····· #ELSE
······· DEBUG Char
····· #ENDIF
····NEXT
· DEBUG CR
· PAUSE 500
··Thanks for any·
·that you may have and all of your time finding them·
Sam
- Stephen
Jeff T.
Thank You For Your Reply
I think it would work but why? Two doors, one stamp?
This is for my ONE Gate for my Drive Way for ONE·going IN·and ONE going OUT
Jeff T.
Hi Sam, unless the intention is to activate the RFID readers in turn 1 2 1 2 1 2 etc you will need a time out for your SERIN's to work independently.
Yes My......·intention is to activate the RFID readers in turn 1 2 1 2 1 2 etc
How would i do this...... you will need a time out for your SERIN's to work independently.
Do you have·any·
TIME OUT·for·the SERIN's that will need
Can you give an example of how to do this or a post where some else has done before
··Thanks for any·
Sam
Just for clarification, the way the code is right now only one person can come and go at a time…That is, if someone leaves, another can’t leave until they come back since the SERIN won’t read that RFID Reader until the other was read. Is this what you intended?
Chris Savage
Parallax Tech Support
ThanK You For Your Reply
How can i fix SERIN so that both can·be readed·ONE·AT· A TIME·so this is not a problem
I want to able to open the Gate with ONE Reader as·I leave and closed the Gate with the other Reader·when the Wife leave to go to work
I need to learn how to this because i have a few people that want the same set up that
I·have if·I can get this to work
··Thanks for any·
Sam
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/30/2007 8:57:25 PM GMT
- Stephen
Your idea isn’t too bad…Recently I suggested a customer use a sensor to detect when a person is scanning a card. He loved the idea…I will share it here in case it helps…
The customer was unable to sufficiently scan several RFID Reader Modules quick enough to be sure not to lose any data. My suggestion involved using a simple IR detector at the panel where the tag was scanned. It simply makes an I/O pin go LOW when it detects an object. For this customer scanning several pins for a LOW takes no time and then he would do a SERIN (with Timeout) for the reader whose IR was triggered. This worked perfectly and he’s had no missed reads since then. This might be an alternative for you. Take care.
Chris Savage
·Can you tell if this would work if not i will try your ·
Reader1:
··· SERIN RX1, T2400, 1000, No_Data1, [noparse][[/noparse]WAIT($0A), STR buf\10]
· #ELSE
··· SERIN RX1, T2400, 1000, No_Data1, [noparse][[/noparse]WAIT($0A), SPSTR 10]
· #ENDIF
· HIGH Enable1
··································· ' deactivate reader
No_Data1:
··· SERIN RX2, T2400,· 1000, No_Data2, [noparse][[/noparse]WAIT($0A), STR buf\10]····
··· #ELSE
··· SERIN RX2, T2400,· 1000, No_Data2, [noparse][[/noparse]WAIT($0A), SPSTR 10]
· #ENDIF
· HIGH Enable2································ ·' deactivate reader
· No_Data2:
GOTO Reader1
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/31/2007 2:13:10 AM GMT
Chris Savage
The IR detector is a good idea and one you should consider in this app. If you decide to include the IR detector you might include something like this to look for a reader being activated.
DO WHILE (IN0=0) AND (IN1 =0)······ 'IN0 and IN1 would be the IR detectors
LOOP
IF IN0=1 THEN
GOSUB Reader1
ELSEIF IN1=1 THEN
GOSUB Reader2
ENDIF
Whatever way you choose make the two reader routines into subroutines, that's a simple case of altering the last couple of lines to include a RETURN and calling them in turn from within your main loop with a GOSUB.
No_Data1:
RETURN
Jeff T.
Note that the above is only possible if the person holds the tag to the reader long enough for the reader to read the tag twice. That is, the first time for the initial triggering, then the second time to actually retrieve the data from the correct reader.
Thank You for your help in this project
I have no way of testing this routine until next weekend I just order two Card Reader Today
but will try it and let you know how well it works
Thanks for pointing out this·............
Waiting a whole second you could miss data at the other reader though. You don’t need the GOTO Reader2 since that line would be executed next anyway
I will have to test and adj delay for the· SERIN and the time that the gate takes to open and close
··Thanks for any·
Sam
Thanks for your reply
Do you where I·get some IR·detectors that are not fooled by the sun·light and will work with a Basic Stamp·and will not cost an arm or a leg Just in case i need to go this route
I·Thank·anyone could give an web link to find this type IR·detectors......
··Thanks for any·
Sam
Your idea could work…If you’ve ever kept the RFID Reader enabled and printed what it sees you will find that holding a tag within range will send the tag ID several times a second. So it is possible to get to quick readings to use in that manner. It is certainly worth testing. I will see if I have time this weekend to do that very thing. Take care.
Chris Savage
Is this what you are talk about do i have the right
Main:
· LOW Enable1
· LOW Enable2
DO
·LOOP UNTIL IN1 =·0 OR IN3 = 0
·IF IN1 = 1 THEN
··· HIGH Enable1
··· HIGH Enable2
·GOSUB Reader1
·ELSE
·IF IN3 = 1 THEN
·· HIGH Enable1
·· HIGH Enable2
·GOSUB Reader2
·ENDIF
·ENDIF
DO
·Reader1:
·· LOW Enable1
· #ELSE
· #ENDIF
· HIGH Enable1
· Reader2:
·· LOW Enable2
· #ELSE
· #ENDIF
· HIGH Enable2··
I change the routine
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/31/2007 3:43:49 AM GMT
There’s no need to keep doing the LOW commands within the DO…LOOP structure. Also, you’re looking for a LOW on the serial lines. By default they will be HIGH. Take care.
Chris Savage
Is this what you are talking about changing
Thank You for all of your help
Main:
· LOW Enable1
· LOW Enable2
DO
·IF IN1 =·0 THEN
··· HIGH Enable1
··· HIGH Enable2
·GOSUB Reader1
·ELSE
·IF IN3 =·0 THEN
·· HIGH Enable1
·· HIGH Enable2
·GOSUB Reader2
·ENDIF
·ENDIF
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/31/2007 3:44:51 AM GMT
Chris Savage
Thank You for all of your help and i will POST how well it works
To Everyone
That has reply to this POST
·And helping learn something new........
··Thanks for any·
Sam
You will most likely have to shadow the pin states in variables since the incoming serial stream is a bunch of highs and lows, meaning that your if statement may not actually see what your while statement saw.
In other words:
s_in1 var bit s_in2 var bit DO s_in1 = IN1 s_in2 = IN2 LOOP UNTIL (s_in1 = 1) OR (s_in2 = 1) IF s_in1 = 1 then ' reader stuff goes here ENDIF ' etc....Post Edited (Harrison.) : 3/31/2007 4:55:00 AM GMT
Non-inverted is idle-HIGH…So when there’s no data the line will already be HIGH. He wants to grab it when it goes LOW. Take care.
Chris Savage
Let me see if i understand what you are saying
s_in1·var·bit················ 'Dose·this hold the valve of the SERIN
s_in2·var·bit
DO
·····s_in1·=·IN1··············'Then when the valve changes then gose to which ever card·reader had the card at the reader
·····s_in2·=·IN2
LOOP·UNTIL·(s_in1·=·1)·OR·(s_in2·=·1)
Thank You Have been alot of help to me in this Project..............
··Thanks for any·
Sam
@Sam - According to what Chris said, you will have to switch back to using 0 as the break out of loop condition. The bit variables are used to store the pin states for comparing by the while and if statements. This allows you to take a snapshot of the state of the pins. You have to do this since the pin state may have changed between the while loop and the if statement that actually reads the card. The revised and slightly more comented code is below:
s_in1 var bit ' holds pin state for comparing, not the actual serial data s_in2 var bit DO s_in1 = IN1 ' store the pin state immediately, which allows you to figure out which sensor triggered first s_in2 = IN2 ' note that IN1 & IN2 are the serial pins coming from the rfid readers LOOP UNTIL (s_in1 = 0) OR (s_in2 = 0) ' quit out of the loop whenever either rfid reader detected a card IF s_in1 = 0 then ' reader stuff goes here ENDIF ' etc....Post Edited (Harrison.) : 3/31/2007 6:26:33 AM GMT
Thank You for Explaning this to me i want understand what is going on in these code routine so i can use them again
Thanks for the idea's.............·These guys·are having way to much fun .............They are all smiles
Start...................
All jokes a side this give some thing to work on next week when the Card Readers· get here and i get the Gate Opener
And will Post this Project when it done and working
··Thanks for any·
Sam
Chirs
The Card Readers came in Today and·I Had Some Time to PLAY with it
The routine that you said would work it dose not But·Thanks for the help that you gave me·I knew what to look for·when you·scan one card reader1 it dose not run check_list until you scan the second card reader
·I came up with something that dose work and i will· share it with you
You can not make the nodata less than 100
If you try to make it less it only reads one card reader but·not the other
·But if you make·nodata· 150 that works the best
You can·HOLD·ONE·CARD on·EACH·READER at the same time and it will READ EACH CARD ONE AT A TIME· with the name of each card about one second or less·for each card ( Card Reader1... Reads Tag1... and Card Reader2..... Reads Tag2... )
One other thing I had to put this·GOSUB Check_List· in because it would not· go to· Check_List·with out this
·One other thing i had to add was EXIT because sometime it would not go to the other reader
These seem to work very well i try it about 30 or 40 time so far so good
[noparse][[/noparse] Initialization ]
Reset:
· HIGH Enable1·································· ' turn off RFID reader1
· HIGH Enable2·································· ' turn off RFID reader2
· LOW Latch····································· ' lock the door!
[noparse][[/noparse] Program Code ]
Reader1:
DO
· LOW Enable1
··· SERIN RX1, T2400, 150, No_Data1, [noparse][[/noparse]WAIT($0A), STR buf\10]
· #ELSE
··· SERIN RX1, T2400, 150, No_Data1, [noparse][[/noparse]WAIT($0A), SPSTR 10]
· #ENDIF
· HIGH Enable1
EXIT
· GOSUB Check_List
'Reader2
No_Data1:
· LOW Enable2
··· SERIN RX2, T2400, 150, No_Data2, [noparse][[/noparse]WAIT($0A), STR buf\10]
··· #ELSE
··· SERIN RX2, T2400, 150, No_Data2, [noparse][[/noparse]WAIT($0A), SPSTR 10]
· #ENDIF
· HIGH Enable2
··EXIT
· GOSUB Check_List
· No_Data2:
GOTO Reader1
LOOP
Check_List:
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 4/6/2007 6:39:56 PM GMT
Your code doesn’t actually look like what I was describing and you still have the extra stuff from conditional compilation in there. I think that is confusing the issues for you. I don’t have two RFID Cards at home currently, but I will get a hold of one in the next few days and see if I can’t come up with a sample code that reads either of two readers. It could be as late as Monday as I am not at Parallax currently. Take care.
Chris Savage
Thank You for any and all help that you can give in this Project
··Thanks for any·
Sam
I frist try this
Main:
· LOW Enable1
· LOW Enable2
DO
·IF IN1 =·0 THEN······ ·' I try this with IN1 = 1· Also it still did not work
··· HIGH Enable1
··· HIGH Enable2
·GOSUB Reader1
·ELSE
·IF IN3 =·0 THEN····· · ' I try this with IN1 = 1· Also it still did not work
·· HIGH Enable1
·· HIGH Enable2
·GOSUB Reader2
·ENDIF
·ENDIF
DO
·Reader1:
·· LOW Enable1
· #ELSE
· #ENDIF
· HIGH Enable1
· Reader2:
·· LOW Enable2
· #ELSE
· #ENDIF
· HIGH Enable2
The problem is that when you scan the frist card read it would wait until you scan the second card reader
until it would read the card·
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 4/9/2007 1:35:23 PM GMT
I will try this if i have time today when i get home from work and let you know if i can
get this code to work
s_in1·var·bit·····'·holds·pin·state·for·comparing,·not·the·actual·serial·data
s_in2·var·bit
DO
·····s_in1·=·IN1·····'·store·the·pin·state·immediately,·which·allows·you·to·figure·out·which·sensor·triggered·first
·····s_in2·=·IN2·····'·note·that·IN1·&·IN2·are·the·serial·pins·coming·from·the·rfid·readers
LOOP·UNTIL·(s_in1·=·0)·OR·(s_in2·=·0)·····'·quit·out·of·the·loop·whenever·either·rfid·reader·detected·a·card
It dose not read cards at all
IF·s_in1·=·0·then
····'·reader·stuff·goes·here
ENDIF
'·etc....
I tried this routine and this dose not work at all
It dose quit the loop but dose not go to check_list routine no matter how i write it
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 4/10/2007 2:33:47 AM GMT
I have tested 50 to 60 time so far so good
Is there any way to shorten it
Reset:
· HIGH Enable1·································· ' turn of RFID reader1
· HIGH Enable2·································· ' turn of RFID reader2
DO
Reader1:
· LOW Enable1······················································
· #ELSE
· #ENDIF
· HIGH Enable1
·· EXIT
· GOSUB Check_List
No_Data1:
· LOW Enable2
··· #ELSE
· #ENDIF
· HIGH Enable2
·· EXIT
· GOSUB Check_List
· No_Data2:
GOTO Reader1
LOOP
Check_List:
··Thanks for any·
Sam
