Should my protoboard buzz?
I got my new protoboard yesterday and I finally found a 9v AC adapter in my cellar. I plugged it in, and turned on the prop. The indicator light comes on, but I'm hearing a buzzing noise coming from the prop. It's pretty quiet though. Should I stop using that adapter?
NerdMaster
For
Life
The day I received my protoboard in the mail, I couldn't find an appropriate power supply, so after checking the datasheet on the regulator, I plugged in my laptop power supply (18 VDC) it ran fine, but the regulator got warm quickly. Since then, I've been running a more reasonable 9 volt.
Brian Meade
"They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
Parallax Forums - If you're ready to learn, we're ready to help.
EDIT: I think my prop's okay. Am I correct in thinking the regulators had reverse-battery protection, and would've protected it?
Post Edited (Jake11611) : 3/22/2007 10:29:42 PM GMT
http://www.national.com/ds/LM/LM1086.pdf
Did not see anything about reverse polarity protection, nor did I see any provided on the Propeller ProtoBoard:
http://www.parallax.com/dl/docs/prod/prop/Propeller-ProtoBoard-v1.1.pdf
If your lucky, it MIGHT still work with the proper power adapter (+9VDC), but probably at least the first +5VDC LM1086 is toast. But I'm ASSUMING the whole board is probably fried.
And if you had a PropPlug, PropClip, USB2SER and your PC's USB Port connected, those·might also have been hit with the AC voltage. Of course this is the worst case scenario, but it would not hurt to check everything connected for proper operation. Sorry to be so 'DOOM & GLOOM' here!
Since the Propeller ProtoBoards are somewhat inexpensive ($19.99), if it turns out the whole board is fried, then chalk it up to a lesson well learned; Always use a multimeter to verify a unknown power supply before you connect it to something you value.
Post Edited (Mike Cook) : 3/22/2007 11:40:26 PM GMT
Maybe it was the ac adapter, heavily loaded by the load, that was buzzing on the table/workbench.
However, looking at the ProtoBoard schematic, that first 10 µF cap may be 'toasted'.
Lessons learned can be costly. Hoping not.
A series diode would help some on protection. But at the cost of apparent lesser battery life by starting with 0.6 v less in use.
Harley Shanko
h.a.s. designn
~~Brian
You should also check your current draw (you can do this easily with a multimeter).
It's quite possible your 5V regulator is broken but yet passing enough current for the 3.3V to work correctly.
I'd say if something buzzes, something is seriously wrong.
Replacing the electrolytic is pretty easy but make sure you clean off all the old solder, as you probably won't be using the
same kind of solder and they might not mix so well. (Also note that Parallax is using a higher temperature solder than
you might be, so adjust your iron accordingly.)
i haven't had it going with the buzzing for more than 3s total... i hope that's not enough time to cause any damage.
~~Brian
When I built my suitcase computer, I used this idea and put diodes across the breadboard power rails in key places. So far it has saved me twice from frying things with incorrect power supply polarity.
Interestingly enough, modern CPU's include so many tiny diodes spread throughout the die (they're used to clamp ringing on inputs, so the CPU can run faster) that the CPU as a whole is almost like a giant high-power diode. One time I tried to diagnose a suspected power supply problem inside a laptop by connecting the 5 volt line from a desktop computer directly to the power pins of the CPU. I accidently pumped 25 amps backwards through the Pentium 2 chip on the laptop when I connected power to it backwards for five seconds. (It was enough to trigger the overcurrent protection on the desktop computer power supply that I was feeding into chip.) When I corrected the polarity, the laptop in fact booted and the CPU was still ok.
Graham
Parallax sells these for the propeller chip.
And i found this.
Thought I would post this for future reference, in case anyone needs it...to ease their mind.
Check out my robot using the propeller robot.tmcp.com.au
If you offer cheap PCB fabrication, perl programming or any other helpful services please email me at.
anthonybmyatt@yahoo.com.au
