watt ,voltage & amp sensor — Parallax Forums
Brian_BBrian_B Posts: 844
edited 2007-03-28 17:58 in General Discussion
Hi,
·I own one of these Dr. Wattson meters . http://www.rc-electronics-usa.com/ammeters/dc-amp-meter.html·· , what kind of sensor do you think their using to read values ?
Thank's Brian
www.truckwiz.com
·"Imagination is more important than knowledge..." ·· Albert Einstein
  • metron9metron9 Posts: 1,100
    The specs on the site show it has a .001 ohm resistance. So they are measuring voltage across a .001 resistance using a microprocessor with an ADC and calculating the values against time. Typically another chip (current sense) that amplifies the voltage across the resistance is used as well.
    Think Inside the box first and if that doesn't work..
    Re-arrange what's inside the box then...
    Think outside the BOX!
