Robolympic Medals Will be Back. . .
. . . I'm pretty certain we'll be making the Robolympics medals again using the SX and SX/B. Anybody remember these? We just received the request to provide them for the June Robolympics. We'll make some extras for our SX users.
(posted to give an idea of level of interest)
Chris
Ken,
· Are these going to be exactly the same ?
· They are really fun to play with and with the Key-Ring is out, programming will be simpler too.
Bean.
"Educate your children to self-control, to the habit of holding passion and prejudice and evil tendencies subject to an upright and reasoning will, and you have done much to abolish misery from their future and crimes from society"
Benjamin Franklin
www.hittconsulting.com
The changes requested were a power switch and to eliminate the 3AAA batteries. I'm not sure what we'll do about the power supply. Any recommendations?
Ken
But I guess that depends on the power supply too...
Was it a weight issue ?
Bean.
Benjamin Franklin
http://www.radioshack.com/product/index.jsp?parentPage=family&summary=summary&allCount=66&fbx=0&cp=2032056.2032152&productId=2104692&accessories=accessories&techSpecs=techSpecs¤tTab=summary&fbn=Type%2F9V+lithium&custRatings=custRatings&features=features&f=PAD%2FProduct+Type%2F9V+lithium&fbc=1&fr=StorePrice%2FRSK%2F00001000%2F00004999&support=support&tab=techSpecs
·I don't think there will be a "perfect" solution at least not till fuel cell batteries are available on the market.
Or these Lithium AA batteries (8 pk is $23) but has 3000 mAh.
http://www.radioshack.com/product/index.jsp?productId=2110936&cp=2032056.2032150&allCount=20&fbn=Type%2FAA&f=PAD%2FProduct+Type%2FAA&fbc=1&parentPage=family
Post Edited (T&E Engineer) : 3/28/2007 4:41:22 PM GMT
I don't think you'll find a comparable power source as inexpensive as (3) AAA batteries.
Just a thought.
- Sparks
The USB Cell batteries .
http://www.usbcell.com/
AA rechargable batteries with built in USB charge connectors to·your PC.
They even have AAA versions.
http://www.usbcell.com/product/4
Amazing technology!
How about two CR123 batteries?
Ken
The CR123 is a good choice but for a couple of bucks more you might want to try the Tadiran 3.6V / 2.100Ah "AA" Lithium Battery from Radio Shack. I have used it·for a laser pointer project. It lasts a long while and costs $13 from Radio Shack. Probably cheaper elsewhere. Since it is in a AA shell - it is easy for packaging too slightly more voltage and much more current for those LEDs.
·http://www.radioshack.com/product/index.jsp?productId=2104708&cp=&pg=2&sr=1&origkw=AA&kw=aa&parentPage=search
A pair of CR123s costs $2.50 and they have 1.6 Ah, so they're a huge value. A friend of mine has extensively tested every single CR123 on the market for a high-volume product and he identified this source. These are every bit as good as the $16.00 pair of Energizer CR123s you buy from drug stores.
I'll still look at the Tadiran batteries, though. Haven't heard of these until now.
I use the keyring to program it, but I "only" have a 9V 500ma (compared to 1Amp in the docs) power supply.
It does work as long as I comment out the "IRC_CAL IRC_4MHZ" directive.
However if I leave it in the program the code in the medal will be erased and then the dialog box will close after briefly display "Calibrating".
It will not program the SX.
Remove this line and it erases and programs without any problems...
The only 1 amp supply I have is 12V, should I give it a try with this power supply or do I risk burning the keyring ?
Does the "IRC_CAL IRC_4MHZ" directive fail because of something else ?
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
