Compilation Consternation
·OK, this program will Compile and Run fine, but then it bombs when I add the part in Red [noparse][[/noparse]Unable to Assemble·due to errors in source code -- "...not within 1/2 of memory page"]
· It blinks S-O-S and then a rapid burst; then I wanted to try some dimming (Intensities), by changing values of PAUSEUS (HIGH + LOW = 1000.)
· I reckon there are better ways to do this, but what's the deal with the Compilation error.· OPTIONX?· STACKX?· Fiddle-stix.
DEVICE sx28, oschs3, TURBO, OPTIONX
IRC_CAL IRC_SLOW
FREQ 28_000_000
PROGRAM starter
starter:
TRIS_A = $0F
RA = 0
X var byte
Y var byte
Hi_Nib var byte
Byt_part var byte
Message:
GOSUB Alpha_S
GOSUB Alpha_O
GOSUB Alpha_S
PAUSE 1250
' Fast Blink series here:
FOR Y = 0 TO 7
HIGH RA.3
PAUSE 100
LOW RA.3
PAUSE 100
NEXT
PAUSE 2000
[color=red]'Intensities[/color]
[color=red]FOR Hi_Nib = 0 TO 7
FOR Byt_Part = $00 TO $FF
HIGH RA.3
PAUSEUS 100
LOW RA.3
PAUSEUS 900
NEXT
NEXT[/color]
GOTO Message
Alpha_S:
FOR X = 0 TO 2
HIGH RA.3
PAUSE 200
LOW RA.3
PAUSE 300
NEXT
PAUSE 750
RETURN
Alpha_O:
FOR X = 0 TO 2
HIGH RA.3
PAUSE 500
LOW RA.3
PAUSE 300
NEXT
PAUSE 750
RETURN
DEVICE sx28, oschs3, TURBO, OPTIONX IRC_CAL IRC_SLOW FREQ 28_000_000 Alpha_S SUB Alpha_O SUB PROGRAM starter starter: TRIS_A = $0F RA = 0 X var byte Y var byte Hi_Nib var byte Byt_part var byte Message: Alpha_S Alpha_O Alpha_S PAUSE 1250 ' Fast Blink series here: FOR Y = 0 TO 7 HIGH RA.3 PAUSE 100 LOW RA.3 PAUSE 100 NEXT PAUSE 2000 [color=red]'Intensities[/color] [color=red]FOR Hi_Nib = 0 TO 7 FOR Byt_Part = $00 TO $FF HIGH RA.3 PAUSEUS 100 LOW RA.3 PAUSEUS 900 NEXT NEXT[/color] GOTO Message Alpha_S: FOR X = 0 TO 2 HIGH RA.3 PAUSE 200 LOW RA.3 PAUSE 300 NEXT PAUSE 750 RETURN Alpha_O: FOR X = 0 TO 2 HIGH RA.3 PAUSE 500 LOW RA.3 PAUSE 300 NEXT PAUSE 750 RETURNBean
"Educate your children to self-control, to the habit of holding passion and prejudice and evil tendencies subject to an upright and reasoning will, and you have done much to abolish misery from their future and crimes from society"
Benjamin Franklin
www.hittconsulting.com
So, "SUB" can be either GOTO or GOSUB depending on whether the subroutine called ends with RETURN?
A FUNC (function) is like a subroutine except that it will return values. Technically a SUB can return a byte, but it's usually considered better form to use FUNC when the routine will return a value.
