Servo comparison
Hi,
I'm working on a project which has several servos which should move 90degrees and back.
I've done it with continuosly rotating servos, and seems like those aren't precise enough for this.
Are standard servos better for this purpose?
Thanks for your help.
You see, a standard servo has a variable resistor feedback element built into it, as well as comparator electronics. So when you give that servo a "PULSOUT" of a certain width (repeated every 20 mSec to 50 mSec) the servo moves the output shaft (and the feedback element) to a particular position which matches that width.
And it can do this through 180 degrees.
Now, when you modify the servo, you disconnect the feedback element and 'stick' it at half-way. When you attach a wheel, now you can control the wheel Forward, Reverse, and Stop. But you lose that precise positioning.
Thus, for what you are asking, a standard servo would work much better.
Is there a way to modify continuosly rotating servo to standard? or do I have to buy new ones?
Shawn Lowe
My last words shall be - "NOT YET!!!"
Parallax may take back your 'modified' servo's, if you haven't broken them.
- Stephen
