VFD to BS2
Hi!
I just want to be sure before my intended buying.
Can this VFD (see datasheet) be connected directly to a BS2? using the serout command?
http://www.farnell.com/datasheets/90808.pdf
The BS2 can control the VFD at the 19.2K baud rate…In fact, our Serial LCD Displays run at 19.2Kbps. The BS2 just cannot receive packets of data at those speeds. With the PSC the BS2 can do 38.4K since it only needs to deal in smaller packets of data. Take care.
Chris Savage
Parallax Tech Support
Chris Savage
Now i got my vfd but now´s another problem.....i have a Board of education to my BS2,I connected as followed
here are the pins on vfd
2,1
4,3
6,5
8,7
10,9
i connected pin 1 on the VFD to my VDD on the stamp and·pin 5 on the VFD·to the VSS on the stamp
but all i get is that the led on the BOE is dimming and after a while turns off...
if the BOE not able to "drive" the VFD?
or what am i doing wrong?
You can see the datasheet on the VFD here http://www.farnell.com/datasheets/90808.pdf
but now for another question...
i guess i should use Asynchrous interface,but what pins should i use....i tried with one wire to connect the pin 2 on the stamp to pin 3 (rxd) on the vfd and wrote "serout 2,16468,[noparse][[/noparse]"Hello world"],but nothing is showing...
anybody got any ideas?
/Regards
Robban
Chris Savage
and wrote serout 2,84,[noparse][[/noparse]"hello world"] but no luck..
is·it correct with the pin 2 from the stamp to the RXD pin on the VFD?
Do i have to connect more pins on the vfd?
Post Edited (Robban) : 3/29/2007 6:37:29 PM GMT
- Stephen
Chris Savage
Chris Savage
