Primary Current Draw
The current transformer I have in my HO train throttle power supply has a primary winding of 115 volts.
The secondary is 24 volts with a center tap and is rated at 10 amps.
How do I calculate the current draw on the primary for selecting a fuse?
24v 10 amps = 241 watts
115v 2.1 amps = 241 watts
I would go with a 2.5 or 3 amp fuse for primary.
But if you want to protect the transformer,
use a 2 amp fuse and don't draw the full load of 10 amps.
Those transformers are kind of expensive aren't they???
Bob
