TX from BS2 and RX into SX28/52 ??
What is the easiest way to transmit a character or string from a BS2 and receive it in an SX (using SX/B).
I have done this before in reverse (Transmit a character from a SX28 to be received into a BS2) - but I want to do the opposite and can't get the coding right.
What I want to do is send DS1302 RTC information from a BS2 circuit over to an SX52 so I can display the information on my 16x16 LED display.
Please help if you can.
Thanks.
Thanks.
At least with the BS2, you should be able to send the Hi-byte and Lo-byte on the same line? but I don't know if thats the way SX/B would recieve it?
Post Edited (Capt. Quirk) : 3/25/2007 1:11:40 AM GMT
It looks like this can be made entirely on a Professional Development Board with a Parrallel LCD (which I have both).
What I dont' see immediately is what to do with the SX28 IO lines (RC).
The SX input goes to pin 15 on the BS2 but what about eh 8 IO lines from the SX28?
Thanks. I will try this in the morning.
All I wanted to do is display time and date information on my SX52 protoboard 16x16 LED matrix that JonnyMac has helped me with. However, as I am running out of variable space on the SX52 circuit, I thought perhaps displaying time and date info on an SX28 would be doable and then transfer·bytes over to the SX52 circuit.
However, since very little if any information exists about a DS1302 interfacing with an SX28, I thought I would start with a·DS1302 interface with a BS2 since it has the DEBUG capability that the SX28 lacks. Going forward I have tried to send over the data between the BS2 and SX52 circuits and I can get single characters but not entire strings of date and time information.
I have attached the code I am working with for both BS2 and SX52 for anyone interested in looking it over.
Post Edited (T&E Engineer) : 3/25/2007 7:54:32 PM GMT
You need to change your BS2 code to just send the strings and nothing else.
I think all you need is this
Post Edited (Capt. Quirk) : 3/25/2007 9:03:08 PM GMT
All I see is the first letter "S" (from Serial LCD) repeated over and over. I think it is because it may take too much time in the STRINGWRITTER routine in sx/b to decode each letter - but not completely sure.
I have also worked on another program (in the reverse way - attached programs). It uses an SX28 to decode a 3x5 keypad (see SX/B 4x4 example for the basics). It displays the character on an 7 seg LED and also transmits it to the BS2 (which I can display the correct keypad entry - 0,1,2,3,4,5,6,7,8,9,A,B,C,D or E. However, it transmits from the SX and receives at the BS2. It is working perfectly.
This program is the opposite of what I want to do with the 16x16 display and BS2 clock (transmits from the BS2 and receives at the SX52).
PS: I also noticed that I sent the wrong BS2 program last time (the HC4LED-xxx is the correct one). The 1st 2 programs are the problem ones and the last 3 programs are the (reversed ones) working for 3x5 keypad from SX28 to BS2.
Thanks.
