For some reason the eeprom does seem to respond right, it seems like no matter what I do I only get an $ff/ 11111111 back unless I'm missing something major in the literature it should go like this for a read cycle:
1. I2C start
2. Master sends a 7 bit address (0000000 through 1111111) with the 8th bit being read/write which would be a 1 cause we are reading
3. Slave sends an Ack which is pulling the line low
4. Slave sends a byte back
5. Master keeps the line high to signal no Ack
6. Master sends a stop
Questions:
Is all that above right? Am I addressing the eeprom right? an ideas on where my code is wrong?
Thank You for the EEPROM I2C Applications. This is A great help to Me. I was gonna post a "new topic" on this, And Boom their it was on the forum.
Its Your "I'll show You" approach, That I like most. From this I learn the most!!!...Your REM statements tell Me whats going on in the code.I learn from this and advance to higher levels of programing code with the BS2 series. Thanks Again
__________________$WMc%_________________Happy New Year
The Truth is out there·········································· E=$WMc%2
' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- SDA PIN 5 ' I2C serial data line SCL PIN 4 ' I2C serial clock line ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- Ack CON 0 ' acknowledge bit Nak CON 1 ' no ack bit ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- slvAddr VAR Byte ' slave address devNum VAR Nib ' device number (0 - 7) addrLen VAR Nib ' 0, 1 or 2 devAddr VAR Word ' address in device i2cData VAR Byte ' data to/from device i2cWork VAR Byte ' work byte for TX routine i2cAck VAR Bit ' Ack bit from device location VAR Byte ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Reset: #IF ($stamp >= BS2P) #THEN #ERROR "Use I2COUT and I2CIN!" #ENDIF devNum = 0 ' device address %000 slvAddr = (location) << 1 addrLen = 0 ' no internal addresses DEBUG CLS, "24C11 Demo", CR ' setup output screen ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: FOR location = 0 TO 127 slvAddr = (location) << 1 GOSUB Read_Byte DEBUG BIN8 slvAddr, " " DEBUG IHEX i2cData,CR 'PAUSE 100 NEXT END ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- ' -----[noparse][[/noparse] High Level I2C Subroutines]--------------------------------------- ' Random location read ' -- pass device slave address in "slvAddr" ' -- pass address bytes (0, 1 or 2) in "addrLen" ' -- register address passed in "devAddr" ' -- data byte read is returned in "i2cData" Read_Byte: GOSUB I2C_Start ' send Start i2cWork = slvAddr | %00000001 ' send slave ID (read) GOSUB I2C_TX_Byte GOSUB I2C_RX_Byte_Nak GOSUB I2C_Stop i2cData = i2cWork RETURN ' -----[noparse][[/noparse] Low Level I2C Subroutines]---------------------------------------- ' *** Start Sequence *** I2C_Start: ' I2C start bit sequence INPUT SDA INPUT SCL LOW SDA Clock_Hold: DO : LOOP UNTIL (SCL = 1) ' wait for clock release RETURN ' *** Transmit Byte *** I2C_TX_Byte: SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork\8] ' send byte to device SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]i2cAck\1] ' get acknowledge bit RETURN ' *** Receive Byte *** I2C_RX_Byte_Nak: i2cAck = Nak ' no Ack = high GOTO I2C_RX I2C_RX_Byte: i2cAck = Ack ' Ack = low I2C_RX: SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]i2cWork\8] ' get byte from device SHIFTOUT SDA, SCL, LSBFIRST, [noparse][[/noparse]i2cAck\1] ' send ack or nak RETURN ' *** Stop Sequence *** I2C_Stop: ' I2C stop bit sequence LOW SDA INPUT SCL INPUT SDA RETURNEverything looks right to me unless I missed something, any ideas?
Post Edited (basejumper9) : 3/20/2007 7:16:55 PM GMT
1. I2C start
Questions:
I need to write an Slave_Byte and a Control_Byte to program it and I need to read it Like Slave_byte, Data_byte1, Data_byte2.
How should I write this program???
I2COUT SDA, Slave_Byte, [noparse][[/noparse]Control_Byte]
I2CIN SDA, Slave_Byte, [noparse][[/noparse]result1, result2] ??????
Need help!!!!
Post Edited ($WMc%) : 1/3/2009 6:38:39 AM GMT
