Crux, due to several requests I will be posting schematics to interface many of our serial devices via RS-232 using the MAX232 chip on Saturday. I won't have a chance before then to do it though. If you can wait until Saturday they will all be posted here on the forums. Take care.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
I am just waiting for an issue to be cleared before I post everything to the Completed Projects Forum…Until then here are the ones for the RFID Reader only…I hope these help. Take care.
There is a difference between the MAX232 and the MAX232A according to the datasheet. The exact part I used was MAX232CPE and I also tried it with the TI MAX232N and both worked. As for the BS2 connections, yes, it is similar. I will be posting complete schematics for all connections within the next two days in the Completed Projects Forum. Today I will post the ones I have that are done. Take care.
Almost forgot…It looks like (at first glance) that the MAX232A simply uses a different size capacitor. In my schematic replace all 1uF capacitors with .1uF for the MAX232A. Take care.
I used the 'PC to RFID.bmp' schematic to successfully communicate with a simple VB6 program via a serial port, however I don't see the LED switch from red/green/red to indicate that the card was read - it just stays red. If I use the BS2 circuit/program from the Parallax manual it does change color. Is this correct behavior?
Update: I've realized that the BS2 code is changing the LED. My mistake. Apparently this reader doesn't behave like some other readers I've used.
Post Edited (zach_smith) : 4/9/2007 9:14:35 PM GMT
Chris Savage
Chris Savage
I am also planning to interface my BS2 with my PC,does the same style apply?
Chris Savage
Chris Savage
····· Just inform me in this forum if the schematics you made is already available.tnx
The schematics were posted back a few posts ago...Did you download them? I have more coming for other hardware...Is that what you refer to?
Chris Savage
····· I didnt notice the post but anyway I tried the one that you gave to me.
I got it running already. Thanks for the help.
