Servo32 and Parallax standard servo - Not turning 90 degrees
I have a parallax standard servo that came with my ping))) mounting bracket and am using it with my propeller board.
But when i use it with the servo32 object it only turns 45 degrees when i tell it to go 1000 and 45 degrees when i tell it to go 2000.
It centers perfectly in the middle at 1500 though, and yes i have tried 900 just to be silly and guess what nothing (didn't even turn, because 1000 - 2000 is full left to full right).
Any suggestions on what i can do to get it to turn 90 degrees.
Thank you
Thank you
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
Is it normal for the 5v regulator on the proto board to get warm. when you are powering a servo and a ping sensor?
Thank you
Post Edited (computer guy) : 3/24/2007 1:58:12 AM GMT
The PING sensor doesn't draw much current. A servo can draw more current (peak) than the regulator can handle. If you can run the servo off a separate 6V or 7.4V power supply, you'll avoid that. If your only power source is more than 7.4V, you'll need to use the 5V regulated supply or some other regulated supply.
