Quick/stupid question about motor power
big_mark
Hi
I have some bipolar stepper motors (4.25volts, 0.425 amps per coil) that I want to drive with an Allegro A3980. I'll be powering them with 24 volts and the A3980 will limit the current with PWM. My question is what should I limit the current to? Should I limit it to 0.425 amps per coil, or should it be lower so that the total power does not exceed 1.80625VA (4.25 volts x 0.425 amps)? If its the latter, the current should be limited to 0.0753 amps (1.80625VA / 24 volts).
I think I'll stick with the A3980 as my preferred supplier (Farnell, in the UK) does not stock the A3986. And the A3986 needs external bridges. The A3980 doesn't.
From the A3980 datasheet, the formula for calculating the current limiting sense resistor is Itrip=Vref/(8*Rsense). I want to use the chip in microstepping mode, so Vref cannot be more than 4volts. I'd rather not have to add another voltage regulator so Vref will be 3.3volts but 3.3volts/8=0.4125amps which is less than the 0.425amps my motors can tolerate so does that mean I do not need a resistor??
Edit: Just had another look at the Allegro A3986 datasheet, and it uses the same formula for working out Itrip. But the maximum Vref is even lower at only 2 volts! So 2volts/8=0.25 which means that the A3986 can only supply 0.25 amps per phase! This is obviously wrong, so what part of this am I not understanding correctly?
Post Edited (big_mark) : 3/23/2007 7:17:59 PM GMT
The max Ref in to he 3986 is 2v, but look at the formula again and understand what that Ref is doing. It is feeding a comparator inside the chip, the Rsense value sets the sense voltage, and is compared to the Ref.
If you want flexibility in the future, design around the 3986 and you can run motors up to 50V, any amp rating. The 3980 is finite with no room to expand beyond it's 1amp limit.
In any case, use the highest voltage you can get up to 35v, then limit to .425 is that is your motor rating. Most steppers have the A rating stamped or stickered on the motor. The hiher the voltage, the better the performance. Start with the Ref pin very low when you start testing, meter the Ref pin and sloly bring it up to the rated value(formula), check for heat on the chip and the motor.
Post Edited (TChapman) : 3/23/2007 10:00:29 PM GMT
Not directly, no. But it is regulating the mosfets based on the values of Vref and Rsense.
I fail to see how using the A3980 will cause me any problems. Since my motors are only rated to 0.425 amps per coil, the total for both is only 0.85 amps. As you say, the A3980 can only handle 1 amp. I'm not whether thats in total or for each winding, but either way it is as much as I think I need. Surely too much current will overheat and/or shorten the life of the motors?
So assuming I'm using an A3980, given a Vref of 3.3 volts and a maximum current of 0.425 amps what should the value of Rsense be? This is what I'm stuck on. Lets say, for arguments sake, I use a 50ohm resistor for Rsense. Using the formula in the data sheet Itrip = Vref/(8*Rsense), we get Itrip = 3.3/(8*50) = 3.3/400 = 0.00825 amps current limit???? That cannot be right, surely.
Edit : After working through the formula like this :
I=V/(8*R)
I*8*R=V
8*R=V/I
R=(V/I)/8
R=(3.3/0.425)/8
R=0.9706
I came up with a value for Rsense of 0.9706 Ohms!
Post Edited (big_mark) : 3/23/2007 10:44:30 PM GMT
Taking a real wolrd example of the 3986,
Itrip(max) = Vref/(8xRsense)
Itrip = 2v/(8 x .4) using .05 ohm sense
Itrip = 2/(.4) = 5 amps
Itrip = x/(.4) = .425
Itrip = .17/(.4) = .425
Vref = .17V to get max current .425
BTW your motor should have a rating on it, not per phase, just a number, usually part of the part number or model number. That is the number to use for max.
**You shouldn't use anything larger than a .1, even .05 is good.
Post Edited (TChapman) : 3/23/2007 11:09:37 PM GMT
Tamagawa Hybrid Stepper motor model ETS535
Step angle : 0.9 degrees
Rated voltage : 4.25V dc
Rated Current : 0.425A per phase
Winding resistance : 10ohm
Winding inductance : 8.5mH
I'm still confused though. The formula on page 10 of www.allegromicro.com/datafile/3980.pdf says that the value of Rs is given in ohms, in which case I need a 0.9ohm resistor. Is that right?
pin is not exceeded"
Hang on I made an error in the formula, I will update it now.
.1 is typical, even .05, .9 is too high, check the datasheet for maximum Sense pin as I posted above.
I changed the formula, I was * instead of /.
Ok, your motor has two phases, and two sense resistors. Each phase is rated at .425, so you calculate based on .425, NOT .425 * 2
Yes it is given in ohms. But that factor is not a fixed number, it is what you use in your circuit. Usuaqlly a .1 or .25, or .05.
Post Edited (TChapman) : 3/23/2007 11:12:37 PM GMT
Itrip = 3.3/(8*0.5)
Itrip = 3.3/4
Itrip = 0.825 - way too high!
However, with a 1 ohm resistor we ge the following :
Itrip = 3.3/(8*1)
Itrip = 3.3/8
Itrip = 0.4125 - Perfect! Just a little under the max. rating for my motors
So I do need a 1 ohm resistor then...
Why do you keep putting 3.3v? The Ref pin is set by a trim pot, from 0 to 3.3. That is how you set it. You going about it backwards, you set the Vref by a pot, usually a multiturn 10k.
Post Edited (TChapman) : 3/23/2007 11:18:12 PM GMT
Itrip = 3.3/(8*0.1)
Itrip = 3.3/0.8
Itrip = 4.125 amps!!!! WAY TOO HIGH
Adjust the trip pot to set the voltage, the trim pot is configured as a voltage divider.
You should write to Allegro tech support and ask for the schematic to the 3980 demo board, just copy what it shows. I understand that you do not have the complete schematic, but Vref is a number that gets set externally by a pot, not by sending it straght Vdd.
The datasheet has a lot of inof on setting the values for Sense, read page 16 for more info. 1 ohm is suggested bo below .5 amps
Post Edited (TChapman) : 3/23/2007 11:24:15 PM GMT
Edit : Just read the table on page 16 and the recommended values for Vref and Rsense are almost exactly what I was suggesting in the first place.
Post Edited (big_mark) : 3/23/2007 11:29:07 PM GMT
There are min and max values for Vref. I didn't check the 3980, but the MAX REF input on the 23986 is 2volts! The 3980is higher, up to 4. . You have to know what ALL the parameters are before making sense R decisions, and REF decisions.
Post Edited (TChapman) : 3/23/2007 11:43:17 PM GMT
