switching regulator
Owen
I am revising a pcb board I just built to handle a larger range of voltages (12v-24v). My previouse design used a single linear regulator to supply 5v and a second regulator to supply 3.3v to the propellar chip but the linear regulator although it can handle the large voltage difference it gets Hotter than I would like. I am thinking about using a switching regulator instead to go from 24v to 5 and then the same linear regulator to go to 3.3v for the propellar chip. I'm a little worried about the switching regulator creating noise problems, most notably for the bluetooth module on the board that acording to spark fun electronics web site it is very sensitive to proper voltage and low noise power. I dont know that the bluetooth would be a problem given that it's power would be coming from the 3.3v linear regulator but I have read that switching regulators can be a problem with RF devices and some times need to be shielded (which I would like to avoid). Can anyone give me some advice as too what switching regulator would be good or if a switching regulator should be avoided all together.
thanks
Owen
thanks
Owen
Digikey has over 6000 in stock as we speak.
Cheers,
Tom Sisk
http://www.siskconsult.com
owen
But, if they're selling surface mount, I'm sure they can take process heat.
Cheers,
Tom Sisk
