MAX7219 LED Driver Sample Code: Hope This Is Helpful
I had a really hard time figuring out the sample code provided by Parallax for the MAX7219 LED Display Driver chip that they offer. I've written a more general purpose testing application that I hope is more easily understood to someone who is unfamiliar with the chip. I have decided to post it here so it might ease other's troubles. I have tried to comment as best I could to explain what is going on. Use this however you see fit. By using this code, you acknowledge that I am not liable for any damage that might result from the usage of this code or any variations on it. Please use in conjunction with the documentation Parallax already provides, which can be found here:
www.parallax.com/dl/docs/prod/appkit/max7298leddisplaydvr.pdf
' {$STAMP BS2}
' {$PBASIC 2.5}
' Program: MAXTest.bs2 (based on MAX7219.B2)
' Author: C. Richardson
' This program runs test patterns and checks specific LED combinations
' for the MAX7219 display controller.
' Hardware interface with the 7219:
DATA_n CON 7 ' Bits are shifted out this pin # to 7219.
CLK CON 5 ' Data valid on rising edge of this clock pin.
Load CON 6 ' Tells 7219 to transfer data to LEDs.
' Register addresses for the MAX7219. To control a given attribute
' of the display, for instance its brightness or the number shown
' in a particular digit, you write the register address followed
' by the data. For example, to set the brightness, you'd send
' 'brite' followed by a number from 0 (off) to 15 (100% bright).
decode CON 9 ' Decode register; a 1 turns on BCD decoding.
brite CON 10 ' " " " intensity register.
scan CON 11 ' " " " scan-limit register.
switch CON 12 ' " " " on/off register.
test CON 15 ' Activates test mode (all digits on, 100% bright)
' Variables used in the program.
max_dat VAR WORD ' Word to be sent to MAX7219.
index VAR NIB ' Index into setup table.
scanNumber VAR NIB 'Number of Digits/Rows
temp VAR BYTE ' Temporary variable used in outputting digits.
odd VAR index.BIT0 ' Lsb of index.
' The program begins by setting up all pins to output low, matching
' the state established by the pulldown resistors.
OUTS = 0 ' All output latches low.
DIRS = $FFFF ' All pins to output.
scanNumber = 0 ' Number of digits/rows...
Main:
GOSUB SetupCodeB
GOSUB DisplayChar
GOSUB SetupNoCode
GOSUB DisplayEach
GOSUB TestChar
GOTO Main
SetupNoCode:
FOR index = 0 TO 7 ' Retrieve 8 setup bytes from table.
LOOKUP index,[noparse][[/noparse]scan,scanNumber,brite,3,decode,$00,switch,1],max_dat 'Get the byte...
SHIFTOUT DATA_n,CLK,MSBFIRST,[noparse][[/noparse]max_dat] 'Send it...
IF odd = 0 THEN NoLoad ' If both bytes have been sent, pulse Load line.
PULSOUT Load,1
NoLoad: ' Else, don't pulse.
NEXT ' Get next item from table.
RETURN
SetupCodeB:
LOOKUP index,[noparse][[/noparse]scan,scanNumber,brite,1,decode,$01,switch,1],max_dat 'Get the byte...
IF odd = 0 THEN NoLoad2 ' If both bytes have been sent, pulse Load line.
PULSOUT Load,1
NoLoad2:
RETURN
DisplayEach: 'Cycles through all possible led combinations on each row/digit...
FOR index = 1 TO (scanNumber+1)
FOR temp = 1 TO 255
SHIFTOUT DATA_n,CLK,MSBFIRST,[noparse][[/noparse]index] ' Send the row/digit...
SHIFTOUT DATA_n,CLK,MSBFIRST,[noparse][[/noparse]temp] ' ...then send the segment id's.
PULSOUT Load,5 ' And load the display.
DEBUG "Current Display: "
DEBUG DEC index, CR
DEBUG "Current Config: "
DEBUG DEC temp, CR
PAUSE 100
NEXT
NEXT
RETURN
DisplayChar: 'Displays all possible CodeB characters...
FOR temp = 0 TO 16
SHIFTOUT DATA_n,CLK,MSBFIRST,[noparse][[/noparse]temp] ' ...then send the CodeB character ID.
DEBUG DEC index, CR
DEBUG "Current Character Code: "
DEBUG DEC temp, CR
PAUSE 100
NEXT
NEXT
RETURN
TestChar: 'Displays specific LED segment combinations for testing..
SHIFTOUT DATA_n,CLK,MSBFIRST, ' Send the row/digit...
SHIFTOUT DATA_n,CLK,MSBFIRST,[noparse][[/noparse]255] ' Enter value to test and see if you've made a specific character...
PAUSE 20000 ' Pause for 20 seconds...
RETURN
Sorry to hear you had trouble getting things going with the MAX7219. There are actually several examples out there besides the one you used, including applications posted in the Completed Projects Forum, such as the following…Take care.
http://forums.parallax.com/showthread.php?p=552892
Chris Savage
Parallax Tech Support
Just wanted to make sure you didn't feel back if the OP didn't reply.
Or as the media would report it:
Phone calls to the original poster were not immediately returned ...
