Wire Wrapping?
Bill Chennault
All--
When I was a LOT younger, we wire-wrapped stuff to experiment with. As I remember it, you could buy a perforated board with through holes and on the back side of the board, the holes were surrounded by solder pads. You could easily insert and solder components and sockets and then wire wrap the circuit together.
MY DUMB QUESTION: Can you still do that? If so, where do I find what I just described above and are there different terms to use today than "yesterday?"
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
The last wire-wrap gun I purchase in the '90s got me a funny look from the sales guy -- "Do people still use these?" he asked.
I believe this kind of prototyping has been supplanted by a few companies that will manufacture completed boards for $20 each or so, including through-hole vias. That, and the prevalence of surface-mount devices.
But you can get a "surf-board" to adapt your surface mount device to a DIP form-factor, so that can still work.
Chris Savage
Parallax Tech Support
Just built a trigger circuit for some radar test setups. a couple of 555's...nothing glorious but fun!
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Chris Savage
I found what I need at Jameco (obviously!). However, I am going to visit Radio Shack first.
Thanks!
--Bill
Chris Savage
Like many of you I also used wire-wrapping. Several years ago, I had a tool that was a hollow metal tube with a wire spool holder on top. You put the tube over the pin, turned the tube several times and the wrap was made and the wire self-cut. I lost this tool and have not been able to find it again.
The ones at Radio Shack are simpler, but the one I had was nice because you had the wire spool and didn't have to use pieces of wire,etc. Does anyone know if and where this kind may be still be purchased?
Thanks.
