Help with the voltage regulator for propeller...
I just had a pcb made that used the LM2937 -3.3·(bought from parrallax's website) to regulate the power going to the prop chip.· I assembled everything and then I noticed it was getting 14v at the output of the regulator.· I did not have a 10uf cap on the output side of it which might be part of the problem but I threw a 10uf cap on the output to gnd and it was still getting a voltage of around 4.2v with all the components on the board but 3.3v if nothing was connected?· I guess this probably doesnt belong on the prop forum but I thought that all of you have used the regulator before to power the prop chips.· What I am wondering is if anyone else had this problem before, and if I'm doing anything wrong.· I've tried like 4 different regulators to see if it was just a bad reg, but all of them did this.· and there is a 5v regulator on it LM2940 which is working fine (I do have caps on the output side of this but it works without them).·
Any suggestions, hints, or mocking would be appreciated!
I'm using this regulator on my Home Brew Propeller Demo Board:
http://forums.parallax.com/showthread.php?p=579595
I did notice that it will float above 3.3 if there is not a capacitor on the output, I think the data sheet suggests 10uF. Attached is a diagram of how I have it connected.
From what I remember without the capacitor, on the output, I was getting around +4VDC out of it,·input power to the voltage regulator was +9VDC or so.·Also I may have had a LED and resistor connected to the output while I was measuring it so there would be a 'load' connected. When I added the electrolytic capacitor to the output, as the data sheet suggests, the output was a rock solid 3.3.
What's your input power?
Another question comes to mind, however: Is there anything on your board that uses the 5V output from the LM2940? If so, and depending on how it interfaces to the 3.3V circuitry, you may be getting 5V backfed into the 3.3V supply through an I/O pin.
I've been looking at LDO regulators and I am concerned with the criticalness of the ESR in capacitors and risk of oscillation. I saw magnitude and phase response curves supplied with the IC makers and I mostly understand how it is supposed to work when the regulator is unloaded. Do I need to be concerned at all with loads such as clocks pulling current at a periodic rate through the regulator?
To see the effects of using vs. not using a capacitor on the regulator, check out the images in this thread...
http://forums.parallax.com/showthread.php?p=637871
Beau Schwabe
IC Layout Engineer
www.glitchbuster.com/wallwart.htm
Brian Meade
"They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
