basicstamp and continous servo position control - if possible
Equipments/Materials
Getting a standard motor is one suggestion but I cannot get a hold of any before the due date.
I'm currently using the For loop to control the timing of the rotation but each time it repeats, the positioning is different. I have tried to add or minus the timining depending on how short or long it stops. After awhile however, the change becomes noticeable.
Post Edited (student2007) : 3/20/2007 4:12:20 AM GMT
- 2 Futaba Continous S148 motors
- basicstamp 2sx
- 4 x AA batteries (6v)
Range at about 0.2 inch which is alright for what I am doing.
The Parallax scheme uses an interruptor type optical sensor with holes/slots in the wheels used to trigger the sensor. You've picked a reflective sensor which should also work. You'll need some kind of reflective spots or strips on the wheel or whatever your servos are driving.
Thank you for the tip : )
