Layout for Spin Stamp board
I have attached the preliminary layout for my Spin Stamp.· You must have Expresspcb to view it.· Expresspcb may be downloaded for free at Expresspcb.com.
The layout is a bit unorthodox but I think it provides maximum flexibility on a small board.· Board size is 4.000 x 1.950.· It has a 5V and a 3V regulator, both ported to a dual 3-pos header.· There is a red LED for 5V and a green LED for 3V.
It has holes and pads for the following, all of which are subject to optional installation:
PS/2 connector, with 5VDC for the keyboard.· Data and clock are pulled
··· up to 3VDC.· Uses Pins 8 and 9, requires two jumpers
24LC512 EEPROM with pullups on SCL and SDA.· Uses Pins 10 and 11.
VGA DB15 HD connector.· Uses pins 0 to 7.· If this option is installed,
··· the eight resistors are plugged into two horizontal headers below the
··· Spin Stamp.· Requires one jumper
RCA TV connector.· Uses Pin 0 to 2.· If this option is installed, the three
··· resistors are plugged vertically into a dual 3-pos header by the RCA
··· connector.
The board also has a Reset button between the DB15 and the Spin Stamp.· If you look at the layout, remember that you are looking at the BOTTOM of the board.· This is the way I have to do layouts in order to make them on my SuperMill.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
··· connector.
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Jeff T.
Sid
Don't have VGA?
Newzed@aol.com
Jeff T.
http://forums.parallax.com/forums/default.aspx?f=15&m=76791
Sid
Don't have VGA?
Newzed@aol.com
You do turn them out pretty fast with that machine of yours.
How many bits did you go thru?
Sid
Don't have VGA?
Newzed@aol.com
Jeff, here are a couple of more pictures to show you what I can do with SuperMill.· They have been posted before but maybe you missed them.· Didn't really have any use for the boards - I just wanted to see if I could make them.
Sid
Don't have VGA?
Newzed@aol.com
Well, you are full of surprises. I did not know the mill would go down to that level.
Sid
Don't have VGA?
Newzed@aol.com
It is basic stamp based and the software for the PC side of things is freely available with source code! You could adapt this to your SuperMill giving you full CNC functionality. It accepts drill files, direct G-Code and there is also HPGL plotting software which you can use for engraving work.
The only problem is it cannot do circular interpolation, a problem which I think you have already solved.
Interested??
Sid
Don't have VGA?
Newzed@aol.com
The link for reference is http://www.milinst.com/ go to robotics and scroll down to the 3 axis machinethere you will find screen shots of the software.
I only mentioned it because i'm sure i read somewhere that you have to manually work out your programs and enter them into the dat section of a spin file, is that not correct??
Damo
I'll take a look at the link you gave me.
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Damo
