Basic Stamp and Transceiver Integration: Need Help Please
I am pretty new to both BASIC Stamps and RF modules.· Me and a few friends are working on a project.·
We have the BS2-p24 stamp module, and the Aerocomm AC4490-200.· We are not using a development board of any time as we are soldering onto a pc board.
Now, if i correctly understand, i need to interface the transceiver to the "serial connection" of the basic stamp. so id only be connecting the transceiver to pins 1-4 mimicing the PC Serial Port connection given in the BS2-p24 module schematic.
First off, am i right with this?
Second, if this is the right interface for these modules.. can someone help me out with the programming to utilize it?· Like i said, I am new to this stuff. And all the help would be appreciated.
Sorry for more info; a temperature sensor gives data to the stamp and the stamp sends that data to the transceiver to be sent out.· The sensor acquires data every 5 seconds.
Post Edited (NightOWL) : 3/19/2007 6:42:52 PM GMT
- Stephen
Pins 1 – 4 represent the BASIC Stamp Programming pins. Unless the RF Modules are RS-232 level and require inverted data you would not use these pins. Take care.
Chris Savage
Parallax Tech Support
and in regards to the sensor data.. the sensor is analog data.. which the stamp cant read, right? so we need to ADC it.. to input it into the stamp.. then from there i have to send it to the transceiver..
below are the pins
Pin Name
1 GO0
2 TXD
3 RXD
4 GI0
5,16 GND
6 Hop Frame
7 CTS
8 RTS
9 GO1
10,11 VCC
12 9600_BAUD
13 RSSI
14 GI1
15 UP_RESET
17 Command/Data
18 AD In
19 DA Out
20 IN_RANGE
Post Edited (NightOWL) : 3/19/2007 11:50:29 PM GMT
TTL is not RS-232…TTL levels would be found at the standard I/O pins so you would not connect to pins 1 through 4 but rather any standard I/O pins.
Chris Savage
in the transceiver's manual.. it lists:
When Interfacing the AC4490 to a DCE (Data Communications Equipment):
DCE Pin/Name - Direction(Tranceiver) - AC4490 Pin/Name
1 DCD - IN - 14 GI1
2 RXD - IN - 3 RXD
3 TXD - OUT - 2 TXD
4 DTR - OUT - 1 GO0
5 GND - - 5 GND
6 DSR - IN - 17 CMD/Data
7 RTS - OUT - 7 CTS
8 CTS - IN - 8 RTS
9 RI - IN - 4 GI0
AND
When Interfacing the AC4490 to a DTE (Data Terminal Equipment):
1 DCD - OUT - 1 GO0
2 RXD - OUT - 2 TXD
3 TXD - IN - 3 RXD
4 DTR - IN - 4 GI0
5 GND - - 5 GND
6 DSR - OUT - 6 Hop Frame
7 RTS - IN - 8 RTS
8 CTS - OUT - 7 CTS
9 RI - OUT - 9 GO1
and i took it as the stamp would be DCE equipment
either way, anyone have any suggestions on how to hook it up if my primary thought was wrong, using the pins i gave before?
Here are the transceiver connections I've used:
pin 2 - TXD - data out of transceiver
pin 3 - RXD - data into transceiver
pin 7 - CTS - output from transmitter
pins 10, 11 - VCC
pins 5, 16 - GND
Use Stamp port pins P0 - P15 to·connect to transceiver pins 2, 3, and 7 (if you want flow control).
Then use serin with pin 2 of the transceiver and serout with pins 3 and 7 of the transceiver
Transceiver signals are TTL so they can be directly connected to the Stamp pins.
Good luck,
- Bob -
im really really new to rf modules, not to mention Pbasic.
'On the transmit side:
BS2p
TXpin con 1······ ··· ' use P1 for transmit pin
FLOpin con 2···· ··· ·' use P2 for flow control
N9600 con $40F0··· ' baud rate is 9600
idata VAR byte
SEROUT TXpin, FLOpin, N9600, [noparse][[/noparse]idata]
' NOTE: flow control is not necessary unless you are close to exceeding the amount of input buffer of the transceiver.
' connect pins 3 and 7 of the transceiver to P1 and P2 of the Stamp
'On the receive side:
BS2p
RXpin con 0············ ' use P0 for receive pin
N9600 con $40F0····· ' baud rate is 9600
idata VAR byte
SERIN RXpin, N9600, [noparse][[/noparse]idata]
'connect pin 2 of the transceiver to P0 of the Stamp
- Bob-
CLIENT
ac4490 (transceiver)
basic stamp
sensor
SERVER
cl4490 (transceiver)
pc
the client side.. gets sensor data every 5 seconds.. which is stored in the stamp.. which is then sent to transceiver to be sent and received by the transceiver on the server side. the server might every now and then send commands and/or data back to the client.
i need to figure out how to set up the client side of things. mainly the pbasic code
can someone help me write or write me a demo code that uses test data to send? i have the ground station transceiver set up to receive signals
Interface Connector – 20 pin OEM interface connector (Samtec TMM-110-01-L-D-SM, mates with Samtec SMM-110-02-S-D)
I bought several from either Avnet or Arrow I believe.
- Bob -
