Bi-color?
I want to do a simple wiring project thet invovles 1 pushbutton, and one bi-color LED. All I want to do is run an LED from a 9v battery so·a red LED, turns green when pressed.·Is it possible to make this without using a microcontroller?
MIKE
MIKE
Use a DPDT push button or switch to control the LED.
In one position, the led is powered with one polarity (will show red) and in the other, the switch changes the polarity applied to the LED and shows green.
Don't forget the current limiting resistor!
Cheers
Tom Sisk
http://www.siskconsult.com
Paul Baker
MIKE
5V | / \ 10k \ / |\ |\ +----------+ ---- \---+---| >O-+-| >O----| |---LED--/\/\-+ | |/ | |/ | H Bridge | | --- +---------| |-------------+ - +----------+▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Paul Baker
Steve
Paul Baker
Steve
