graphics object font without descenders
Is there a version of the graphics object font that doesn't have descenders ?
Or how would I modify the data so the characters are higher (g,j,p,q,y) ?
Bean.
"Educate your children to self-control, to the habit of holding passion and prejudice and evil tendencies subject to an upright and reasoning will, and you have done much to abolish misery from their future and crimes from society"
Benjamin Franklin
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Coming soon! Propeller based OSD module www.hittconsulting.com
Bean.
Benjamin Franklin
Bean.
Benjamin Franklin
If you look at the vector character definitions in graphics.spin, you can see what needs changing. Before the character·def's, there are some comment lines which define the vector format. A little experimentation will get you there quickly.
Chip Gracey
Ah, yes I see how it works now. I can just adjust all the "y"values up by 3 or 4 on each character I want to shift up.
Bean.
Benjamin Franklin
